vacuum y rubber hose. can some one help me find a site where to find it?
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, vacuum y rubber hose. can some one help me find a site where to find it? in Cadillac Engine Discussion; i cant seem to find an original rubber y vacuum conect hose. from carb to pull off then conects to ...
    1974 Cad. 472 quadra is offline Cadillac Owners Member
    Automobile(s): 1974 DeVille
    Sep 2012
    37
    1
    i cant seem to find an original rubber y vacuum conect hose. from carb to pull off then conects to T conector that runs to air pump/ smog pump? then other end runs to vacuum switch y rubber hose.jpg i have highlighted the part in red. Help. thank you
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,253
    Re: vacuum y rubber hose. can some one help me find a site where to find it?
    Go to the Help! racks at any large parts store - any of the proper sized connector T's, Y's, X's and vacuum hose will work just fine - I use them all when rebuilding various QJ's on Olds 455 marine engines. No problems.
