Results 1 to 2 of 2
Thread: Need help with overheat 425 Cadillac eldorado
    alshaer is offline Cadillac Owners Member
    Automobile(s): Eldorado 1978
    Aug 2012
    39
    4
    Hi all ,
    I have Cadillac eldorado 1978 and ther is high prassur in in coolent line but coolent temperature light is off so,
    I need to now what's the range of 424 water temperature ?
    Is it normal the prassur in the coolent line ?
    Thanx
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: Need help with overheat 425 Cadillac eldorado
    The 425 uses a 16 # pressure cap. Check your cap. The seal on the cap can fail and allow the radiator to overflow.
  • You may not post replies
