bad engine shake
Results 1 to 10 of 10
500, 472, 425, 368 Discussion, bad engine shake in Cadillac Engine Discussion; When the car is idling the engine shakes pretty bad. When I give it some gas it seems fine....
    72HearseGuy is offline Cadillac Owners Member
    Automobile(s): 1972 fleetwood hearse
    May 2012
    27
    35
    bad engine shake
    May 2012
    27
    35
    Re: bad engine shake
    The rest of the car doesnt shake so Im thinking the engine mounts are crap.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I have seen some messed up carbs make an engine shake. If it is the carb it will probably get worse. Although you have a 72 with points so all bets are off. I always blame the points first.
    May 2012
    27
    35
    I could try the points first cuz they're pretty cheap. Are they pretty easy to replace?
    May 2012
    27
    35
    How badly will changing the points mess with the timing?
    Feb 2007
    Maine
    55
    3,310
    I may have misunderstood your shaking. I was thinking of a bad shake like an out of balance washing machine. If yours is a mild shake and it runs pretty good.........it could still be the points; especially if you don't know when they were last changed. They do have to be adjusted so you either need some old guy to do it or read up some old manuals.
    May 2012
    27
    35
    They looked pretty dirty, but the rotor and inside the cap were clean though. They're all cheap parts so I'm gonna do all three. My neighbor said hed help me adjust em. I'll report back when they're done.
    May 2012
    27
    35
    The dist cap wasn't sitting snug cuz one of the spring clips was broken.
    Bigger=Better is offline Cadillac Owners Member
    Automobile(s): 1978 Eldorado Biarritz
    Apr 2011
    4
    I had the same problem, turned out to be a worn throttle shaft bore in the carb base plate.
    Even tiny play will allow additional air into the engine causing rough idle and/or stalling.
    -> carb overhaul
    You could also check torque on carb and intake manifold bolts.
    Worn carb gaskets may cause leaks as well.
    78cadillacfleetwood's Avatar
    78cadillacfleetwood is offline Cadillac Owners Member
    Automobile(s): 1978 cadillac fleetwood brougham d'elegance sedan and 89 cad
    Aug 2012
    calgary alberta
    33
    1
    my 78 fleetwood used to shake bad at idle until i made her suck back a can of seafoam threw the pcv valve and she is still fine right now
  13. Remove Advertisements
