timing chain
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, timing chain in Cadillac Engine Discussion; How big of a pain in the butt is it to replace on the 472?...
    72HearseGuy is offline Cadillac Owners Member
    Automobile(s): 1972 fleetwood hearse
    May 2012
    27
    35
    timing chain
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    Re: timing chain
    to do it right you have to drop the oil pan. this way you can seal up the timing case cover without any leaks.. and when the pan is off you can clean out the oil pick-up tube. it will be loaded with little plastic pieces from the gear and valve seals...BE CAREFUL don't mix up the bolts from the pick-up tube and the timing gear.. they are almost the same but the tube bolts are longer and will hit the block..Only use a good roller chain with the steel sprockets.. they start at about $80..If you are keeping the stock cam use the +4 degree keyway on the new gear..I'll give you more info if you do it..
    May 2012
    27
    35
    Re: timing chain
    It'll have to wait until after I move. Unfortunately I wont have time before so i hope it doesnt decide to go on the drive. Thanks for the info.
    53 COE 472 is offline Cadillac Owners Member
    Sep 2012
    1
    Re: timing chain
    Quote Originally Posted by drmenard View Post
    About to tackle this - please PM me....... or post more tips to the thread.......
    Thanks.
    May 2003
    Massachusetts
    1,181
    Re: timing chain
    I would PM you but you don't have enough posts to recieve one.. Before you drop the pan I would drop the Y pipe and unbolt the motor mounts, thats from the bottom.. Thats so you can jack up the motor to get the pan off...
  8. Remove Advertisements
