making a 74 500 perform like a 1970 500
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
500, 472, 425, 368 Discussion, making a 74 500 perform like a 1970 500 in Cadillac Engine Discussion; they started choking these engines more and more after 1970......any advise?...
    davefedoroff is offline Cadillac Owners Member
    Automobile(s): 1974 Eldorado Convertible
    Jul 2012
    37
    4
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    381
    After the timing chain is replaced, step one is a low restriction (dual) exhaust
    WITHOUT that terrible cat converter. Be sure the ignition is in good shape;
    mine would get an HEI. Bruce Roe
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,182
    Re: making a 74 500 perform like a 1970 500
    Try going to the MTS website. They sell all the parts for these motors. You can learn all you need to know there.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by BRUCE ROE View Post
    Hi Bruce.
    The 74 500 already has HEI.
    If I hear the word timing chain again I'm going to puke.
    I've ripped apart a lot of these engines and have not come across a chain bad enough to cause any power issues yet. Also have not seen the plastic coated ones on Cadillac engines. If they used them I missed it. I'm tempted to tear into my all original 368 just to look.
    The oil slinger may be a reason.
    Jul 2012
    37
    4
    what about the compression ratio? the 1970 was around 10:1, 74 8:1. did this do a ton to starve power? is the only way to change that replace heads and or pistons?
    also, was looking at headers online, and they're really expensive. how restrictive are the stock exhaust manifolds? wouldn't i see great gains if i just put a dual exhaust in with thick pipes, free flowing mufflers and removed cat converter?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Yes. I wouldn't waste money on headers. A good tune up and dual exhaust will make plenty of power. In high school I used to race plenty of "hot rods" with my Mom's Olds 98 with 455 and single exhaust. A lot of people got surprised by a stock quiet vehicle with a good tune up. If you need more power than that, then the engine should come out for a full rebuild from the MTS catalog.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Quote Originally Posted by The Ape Man View Post
    I've cleaned the remnants of the plastic coated gears out of the bottom of a few oil pans! I'm not sure what years they were used, but I'm pretty sure the oil pan of my '72 472 was full of plastic pieces!
    68
    82,081
    Quote Originally Posted by davefedoroff View Post
    I think that was the big killer. Yeah, probably mill the heads and/or change pistons.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I had the heads on my 472 milled to raise the compression to 9:1. Along with porting and a better cam, it made a huge difference.
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by caddydaddy View Post
    I've cleaned 16 broken piston skirts out of Cadillac 500 oil pans but missed out on the plastic. I know that plastic was death for later V6s if not removed.
    tsgrpr97's Avatar
    tsgrpr97 is offline Cadillac Owners Fanatic
    Automobile(s): 74 Coupe DeVille, 99 DeVille D'Elegance (diamond white)
    Nov 2008
    Pennsylvania
    100
    Hi Bruce.
    I think HEI was an option in 74. At least on the deville.
    Jul 2012
    37
    4
    how much did it cost you to have the heads milled?
    Feb 2005
    Southern NJ
    54
    2,096
    Quote Originally Posted by tsgrpr97 View Post
    Yes it was an option in 74 so it's possible to have a 74 500 engine with points.
    So I'm off on that point. Some of the people from the old CML would probably have the production figures.
  16. #14
    DouglasJRizzo is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 hearse, 1976 hearse
    Nov 2010
    Franklin Lakes, NJ
    53
    865
    Making good power from a 74 500 motor is fairly easy. First, there's no cat on a 74, those were introduced in 75. If you must keep your cats for the street there are low restriction varieties that don't choke the flow like the original GM cats did.
    MTS (there may be others) has all manner of goodies to wake up the Cad. Points ignition systems should be scrapped on all but some show cars that need to remain all original. They just don't throw enough fire to ignite todays swill gasoline.
  17. #15
    Jul 2012
    37
    4
    mine has the hei option. it looks like there are two mufflers, makes sense cuz the car's so quiet. the exhaust doesnt look restrictive at all until after the first muffler. then it makes all sorts of bends before going through the second muffler and out the tailpipe. what if i just cut the exhaust after the first muffler? how restrictive were the stock mufflers?
    im thinking if i do K&N air filter, ram air intake, good tune up and free up exhaust a little i should get much better power out of it, no?
  18. Remove Advertisements
