1969 472 heater hoses
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, 1969 472 heater hoses in Cadillac Engine Discussion; We are restoring a 1957 series 62 with a 1969 472 engine There are no heater hoses hooked up and ...
    jerrywagner is offline Cadillac Owners Member
    Automobile(s): 1957 Coupe DeVille
    Aug 2011
    3
    There are no heater hoses hooked up and we cannot locate the locations on the block where these should be. Can anyone tell me where these are please?
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,178
    Re: 1969 472 heater hoses
    there were 3 places through the years that the heater hoses were connected... The back side of the passanger head.. Thats at the firewall.. Then there is right next to the thermostat ,they always use this one.. And the last one was a return hose to the radiator...thats the best that I can tell you.. What I did and I think works best is if the passanger head does not have a port ,drill and tap with a pipe tap and put in a street elbo.. This will give real hot coolant to the heater core and great heat..They used this on some years of eldorados...
