identifying year
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, identifying year in Cadillac Engine Discussion; I found a used 472 motor only an hours drive away. Problem is the guy doesnt really know anything about ...
    72HearseGuy is offline Cadillac Owners Member
    Automobile(s): 1972 fleetwood hearse
    May 2012
    27
    35
    identifying year
    I found a used 472 motor only an hours drive away. Problem is the guy doesnt really know anything about it. How would I be able to identify the year? Also it has a rear sump oil pan installed. Can that be changed back pretty easily? For 100 dollars it could be a safe gamble.
    I need an extra motor I can rebuild while driving the car.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: identifying year
    Well.........there's always the google. I was curious myself and took a look.
    http://www.cad500parts.com/catalog/page2.htm
    It is pretty tricky to tell them apart but at least you can verify that it isn't a 425 or 368. I don't think any 472's had rear sumps but not sure about the Eldo's
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,173
    You can tell what you have by the casting numbers..The block number is in the back of the motor by the oil pressure sender and the head number that can be seen after you take off the rocker arm cover.. these two numbers will tell you what 472 that it is... If it is a 500 you will also need the crankshaft casting number..
    68-68 eldos had rear sump 472's....
    May 2012
    27
    35
    I sent him an email asking for the casting numbers. No response yet.
  7. Remove Advertisements
