Ticking by valve cover
Results 1 to 11 of 11
500, 472, 425, 368 Discussion, Ticking by valve cover in Cadillac Engine Discussion; After I changed my oil I noticed a ticking coming from near the front of the passenger side valve cover. ...
    72HearseGuy is offline Cadillac Owners Member
    Automobile(s): 1972 fleetwood hearse
    May 2012
    27
    35
    After I changed my oil I noticed a ticking coming from near the front of the passenger side valve cover. i dont know if it has anything to do with the oil change its just when I noticed it. How do I tell if it's coming from under the valve cover (lifters?) or if its maybe a leak in the exhaust manifold? The noise doesn't go away when the engine is revved. It seems to get faster. It's there whether the engine is cold or hot.
    It's not low on oil
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,933
    Re: Ticking by valve cover
    With the engine cold, check the manifold bolts.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    There is a spring clip that keeps the rocker in place.. If the clip breaks it can make a clicking sound and the rocker can come off.. And if the rocker comes off you have a 50/50 chance the lifter can pop out of its bore... If the lifter pops out the motor will lose oil pressure...I would take off the cover and see where the noise is coming from...
    May 2012
    27
    35
    Can I start the engine with the valve cover off or will squirt oil everywhere? Sorry if these are stupid questions. I'm new to a lot of this.
    May 2003
    Massachusetts
    1,181
    It will do more dripping than squirting..First thing is look at the clips without starting. each rocker has one clip to hold it in place..I would put rags around to catch most of the oil...But before you take off the cover do what Jay said and make sure its not a exhaust leak..I like to use a hose, put it to my ear and put the other end around where there could be a leak.
    May 2012
    27
    35
    Thanks guys. I'll be able to do some poking around tomorrow. I'll update on what I find.
    May 2012
    27
    35
    I got a stethoscope and poked around a bit. When I touched the prod to the bottom of the valve cover near the front I could hear the ticking. That leads me to think its coming from under the cover. Am I right in my thinking there? I took the cover off and checked the clips. They seemed ok; all rocker arms in place and tight. I ran the engine for a minute or two. Everything seemed to move freely. It seemed that some of the rocker arms got more oil than others. Could that lack of lube be causing the ticking noise. Possible course of action: replace pushrods cause theyre blocked?
    May 2012
    27
    35
    Does it take a few minutes for the oil to come out of all the pushrods? And are the pushrods suppose to spin at all? Cuz mine didnt in the minute or two I ran it. The engine was hot when it ran.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    The push rods should dance some. With the engine running, push down on the rocker on the push rod side, when you find the one that is bad, the clacking will stop. At the front of the engine, above the oil pump is a port. It has a pipe thread plug in it. Remove the plug and install a oil pressure gauge to find what the pressure is coming off the pump. If this pressure in lower than 28 lbs. at idle, there may be something restricting the oil pick-up screen or the tube or the pump may be bad.. There is another port at the back of the engine where the electronic pressure switch is located. If the pressure here is considerably less than the pressure at the port above the pump, then there is blockage in the oil galleys that feed oil to the lifters and the cam.
    May 2012
    27
    35
    Thanks deVille33. I'll check it out on wednesday. Do I need the valve cover on when checking the pressure?
    Mar 2006
    1,493
    No. I won't make any difference with cover on/off.
  14. Remove Advertisements
