368 Distributor on the bigger engines
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 368 Distributor on the bigger engines in Cadillac Engine Discussion; I scored a 368 electronic distributor today at Pick n pull. To use it on a carbed 425, I would ...
    ferrisworld is offline Cadillac Owners Fanatic
    Automobile(s): 1979 Sedan Deville
    Feb 2005
    Sacramento, CA
    444
    I scored a 368 electronic distributor today at Pick n pull. To use it on a carbed 425, I would need a stand alone controller for it. What should I get? I'm wondering if the smog people are gonna get upset if I have it though. Maybe if I put a fake vacuum advance next to it?
    Also I was wondering, and this might seem like a dumb question, but if I get the Cloyes 3911 or whatever timing chain and advance the full 4˚, won't that change my ignition timing too? If so how much? I guess I don't really get how setting all that up works.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,169
    Re: 368 Distributor on the bigger engines
    The 368 distrubtor will work on 425,472 and 500 motors... But the F/I distrubtor must be used to control the spark with a computer... this will need some sensors... If your going to do all that you might just make it fuel injected... If you are going to use a carb you best use a distrubtor with centrifical and vacume advances...
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    366
    My experience is, there is plenty of advantage to electronic (programable) spark
    maps, and that includes with a carb. I did it with a crank trigger system. Its
    far easier to get right than a fuel injection system. But most people do injection 1st,
    and think about the spark later (much, much later). Bruce Roe
  5. #4
    Feb 2005
    Sacramento, CA
    444
    Alright, well, at least I have it! It was from an 81, so if the 864 covers and solenoids are still there next time I'm gonna take those too and maybe try to adapt one day like that Swedish dude did.
  6. Remove Advertisements
