Losing Oil in 1976 eldorado
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, Losing Oil in 1976 eldorado in Cadillac Engine Discussion; Hey guys, i have a 1976 eldorado and ive been losing oil like crazy since i got the car, the ...
    cullen747 is offline Cadillac Owners Member
    Automobile(s): 1976 Cadillac Eldorado Convertible
    Feb 2012
    24
    7
    Hey guys, i have a 1976 eldorado and ive been losing oil like crazy since i got the car, the strange thing is that the block is dry, i
    have no leaks from the oil pan, and Im not getting any blue smoke, only bad smoke is the white smoke in startup. Ive been using
    valvoline 10w 40 which was recommended to me, and i dont know if the engine is just eating the oil up, any suggestions?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Losing Oil in 1976 eldorado
    Are the valve covers stock? I would double check the PCV and breather to make sure it isn't sucking oil form there. The Valvoline 10-40 is good oil for today's cars but probably doesn't have enough zinc for your engine. I wouldn't drain it right away but next oil change you should try a 15-40 truck oil.
    Feb 2012
    24
    7
    yes the valve covers are stock, but i will check the breathers and pcv, if they are sucking, what should i do? and im going to change the oil soon, so i will definitely switch and try out 15w 40
    1970CadillacCalais's Avatar
    1970CadillacCalais is offline Cadillac Owners Member
    Automobile(s): 1970 Cadillac Calais
    Sep 2011
    Jacksonville, Fla
    69
    Also check your oil sending unit. That's where I was losing oil from. Replaced it and cleaned the area and haven't seen any more yet.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,178
    15-40 atleast, I also use a 20-50... and a can of STP or a oil additive like that with zinc..They have been taking some of the zinc out of the diesel oils.
  8. Remove Advertisements
