oil pump question
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, oil pump question in Cadillac Engine Discussion; I have a 472 Cadillac motor in a 4 seat dune buggy. My question is I don't think its pumping ...
    badams270 is offline Cadillac Owners Member
    Automobile(s): 472 cadillac
    Feb 2012
    40
    4
    oil pump question
    I have a 472 Cadillac motor in a 4 seat dune buggy. My question is I don't think its pumping oil. I pulled the filter off and turned the pump by hand and oil came out. I put a new filter on and turned the pump with a pump primer. Its easy at first then becomes very hard like pressure building but no where to go. Could there be a blockage somewhere?
    drmenard is online now Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,176
    Re: oil pump question
    Is this a new pump? I have heard that some new pumps that the pressure relief get stuck open and lose pressure.. What guys do with a new pump , because of this is, remove the set screw and take out the spring and piston.. Then they polish the piston hone the bore and make sure there are no burrs and slids freely... Did you have the motor apart?
    grassisgreener is offline Cadillac Owners Member
    Automobile(s): 1968 Sedan DeVille - Bone Stock - Kasmir Ivory
    Dec 2011
    Rhode Island
    37
    31
    All I can add is don't buy the pump Auto Zone has. Better to stick with the cast iron pump and buy a rebuild kit.
    Post a picture of the 472 in a buggy please.
    Feb 2012
    40
    4
    So, if I'm looking at the bottom of the pump. There is a hole thats open, and one with a little flap. What is the port with the flap? I have a rebuild kit, plan on installing it soon.
    Feb 2012
    40
    4
    Well, still no oil getting to the valve train? Pulled the front pressure switch, and its pumping that far. Pulled the back pressure switch and I get oil back there. Anyone know why its not pumping into the heads on either side?
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Have you done work on the heads? Did you remove the rockershafts? You may have the shafts mounted so they block at oil passage. There is a special bolt (hollow) that goes into the oil passage port.
    Feb 2012
    40
    4
    I haven't done any work to the heads. Both sides no oil. I have a manual coming form ebay, guess Ill have to wait. I got a oil pressure testing kit last night and have 35 lbs at idle. Where is this hollow bolt you speak of? The rockers and valves get lubricated through the push rods, right? Thanks for your help!!
    May 2003
    Massachusetts
    1,176
    The rockers get there oil through the pushrods from the lifters... There are freeze plugs under the intake that plug a oil passage .. If one pops out you loose a lot of pressure.. If the lifters are clicking they could haved lost pressure...But if you got 35psi I would pull out some pushrods and see if they are blocked..
  11. Remove Advertisements
