water pump gph
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, water pump gph in Cadillac Engine Discussion; I have been trying to find out the gph of the stock water pump on a 1975 500 cu. in. ...
    miniman1 is offline Cadillac Owners Member
    Automobile(s): 1975 500 cu in engine in hot rod
    Dec 2011
    68
    1
    water pump gph
    I have been trying to find out the gph of the stock water pump on a 1975 500 cu. in. caddy engine. Is there anyone out there who might be able to answer this. Trying to add an electric pump to the system in my hot rod to help the cooling.
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    386
    Re: water pump gph
    Quote Originally Posted by miniman1 View Post
    Electric pumps are poor competition to belt driven, I would concentrate on a clean cooling system,
    a REALLY GOOD 4 row radiator, perhaps a "wetter" additive, and maybe some electric fans to help
    when stopped at idle. You have the 7 blade clutched factory fan with shroud, and an overflow tank?
    Bruce Roe
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: water pump gph
    I'm with Bruce. The 500 is relatively easy to cool if all the pieces are sized properly. More flow may not make any difference.
    Been there.
    You can take advantage of the extra cooling system loop used for heat. Rear of passenger side cylinder head fitting returning to radiator below fill cap.
    If room for radiator size is a problem an aux cooler could put you over the top.
    Also make sure the spark advance and ignition timing are not causing extra heat by being retarded.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,187
    Re: water pump gph
    5906.jpgLet me add this... Get a flow cooler waterpump, it makes all the differance...It has a closed impeller, looks like this.Years back napa sold one that looked like this too...
  7. Remove Advertisements
