Results 1 to 5 of 5
Thread: How Heavy is 472 engine with acessories and fluid? bent engine stand
    YourMainParadox is offline Cadillac Owners Fanatic
    Automobile(s): 1974 Cadillac Hearse 472
    Apr 2010
    493
    Ok so I was trying to put my engine on an engine stand and I bent the sh*t out of it when the full engine sat on the engine stand. I have all the accessories on the engine minus the carb and the alternator. How heavy is the COMPLETE engine with fluids?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: How Heavy is 472 engine with acessories and fluid? bent engine stand
    My latest Hot Rod magazine did a test of Harbor Freight engine stands. They put an engine on them and then pushed down on them some more with a fork lift. The cheapo one bent but didn't break but only after exceeding the weight rating. A 472 with accessories and fluid shouldn't be more than 600 lbs but still pretty heavy for the cheaper engine stands. I was always worried the engine would break off and fall on my toes. It was nice to see that they bend but don't break. It sounds like you need a better engine stand now.
    Feb 2007
    Maine
    55
    3,310
    Oh yeah, a picture would be cool.
  5. #4
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Most large American V8s were much heavier than a Cadillac 472/500/425/368
    The Cad engines were thinwall castings with high nickel alloy. They are smart and relatively light.
    Yer engine stand might be too small.
  6. #5
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,874
    ~625 pounds, dressed - just about the same as the 455 Olds marine engines that I build, and I use a 1250# rated 4-wheel long leg engine stand.
  • You may not post replies
