New to classic Cadillacs, why can't i locate the 472 water pump belt?
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, New to classic Cadillacs, why can't i locate the 472 water pump belt? in Cadillac Engine Discussion; Well, Stepped off the deep end yesterday and bought a 1971 Cadillac knowing nothing about classic cars. The cars I ...
    graphixv is offline Cadillac Owners Member
    Automobile(s): 1971 Cadillac commerical chasis
    Oct 2011
    Well,
    The cars I work on are all 1990's.
    it's a 472 commercial chasis (hearse).
    I need to replace all the belts immediately and I can't figure out why I can't locate a belt
    that says it runs to the water pump anywhere. comp, ps, fan, alt I got. Nothing says belt
    to water pump. Am I missing something?
    Are there any basic guides here for what I have to remove to replace the belts?
    Thanks,
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    Re: New to classic Cadillacs, why can't i locate the 472 water pump belt?
    To make it so you could not disconnect the smog pump this is what they did with the belts.. As long as yours is still stock , because many people used different year pulley set-ups so they could take off the smog pump and parts..The stock set up had 2 belts the same size going around crank pulley A/C compressor and power steering pump.. Then they have a belt that goes around the crank , waterpump and smog pump.. then the last belt goes around the second groove of the waterpump to the alternator..So if you take off the smog pump belt you got no waterpump or alt.
