i wana put manual behind my 425
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, i wana put manual behind my 425 in Cadillac Engine Discussion; i stuffed 79 425 into a 86 c15 and now im starting to think about how much more fun it ...
    fuknuz is offline Cadillac Owners Member
    May 2011
    Crivitz, Wisconsin, United Sta
    27
    66
    i stuffed 79 425 into a 86 c15 and now im starting to think about how much more fun it would b to b a manual. thing is, idk what trans to be looking of or what to do bout a flywheel. ik ppl have done it, could anyone help out with finding the info?
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: i wana put manual behind my 425
    You need a BOP bellhousing. You will probably have to make up your own linkage. I believe the linkage from a Pontiac leMans might get You close. You can use a Muncie, a Sginaw or a Doug Nash 5 speed. The choice is Yours. You could probably get aflywheel from any of the after market manufacturers, Schneider, Zoom or other, If any are still in business. You might turn one up at an end of the Season swap-meet in your area.
    May 2011
    27
    66
    thanks. theres no swap meats within 50 mi of where i live lol and i also have a thread ovef at hot rodders and they are talking about a bearing retainer issue. im new to the gm manual scene.
    aeronca36606 is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Coupe Deville 4.1 V8 & 4.3 V6 Deisel & 1970 Eldorado
    Sep 2005
    East Tennessee
    773
    The easiest bell housing to find will probably be from an early Jeep CJ5. The early CJ5 has a Buick V6 as a common option. It was called the Dauntless V6 by Jeep. This jeep was also available with a Borg Warner T18 4 speed. One of the other advantages with using this bell housing is there is a lot of after market support for adapting many different transmissions to it. Check out Novak.
    http://www.novak-adapt.com
    They may also be able to tell you what will work as i am sure someone has put one of these engines into a jeep J series pickup.
    May 2011
    27
    66
    ok checked out novak, good link but cuoldnt find anything on the bbcad's might call tech later tho. thanks for the info on the jeeps tho. its looking like this is gunna be a good option for me. i found a local shop that might have a muncie laying around. gota look into it yet.
    Mar 2006
    1,493
    Because your set-up isn't original, and is a conversion, the linkage will not be stock. You will need the fixture for the cross tube to the frame, the hemispherical ball and linkage to tie it all together. I believe you can get close using the linkage from a 70's pontiac leMans, as they used the BOP housing you need. Another option you may use would be the linkage for the chevrolet truck, but it would not be a direct bolt in. Chevy and GMC had different linkages for different truck models.
    Sep 2005
    East Tennessee
    773
    There are several companies making a hydraulic clutch conversion for the Jeep. Possibly could use here.
    The Cadillac 425 has the same bell-housing bolt pattern as the Buick/Jeep V6. The only part i am not sure of is whether the starter is on the same side.
    May 2011
    27
    66
    my starter is on the pass side as u probly already know. im gunna b looking around to see whats avalible localy. i will keep this updated with what i find and let me know what u think
  11. Remove Advertisements
