oil leak from back of motor
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, oil leak from back of motor in Cadillac Engine Discussion; hi i have a 79 425 all stock thats leaking oil out the back of the motor. i thought rear ...
    fuknuz is offline Cadillac Owners Member
    May 2011
    Crivitz, Wisconsin, United Sta
    26
    66
    hi i have a 79 425 all stock thats leaking oil out the back of the motor. i thought rear main but i have the dust shield on and i get just as much oil drpping off the starter so im thinking its comming from up higher. im replacing the original valve cover gaskets as i wright this so maybe that is it but im just wondering if theres anything back there that could also leak. thanks
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Re: oil leak from back of motor
    Yes, the oil pressure switch is located on the block in the middle over the bell housing flange. They usually have 3 terminals in those years. One to complete ground for the idiot lamp and 2 for power to the electric choke.
    You need a specialty socket to unscrew the thing if it is the problem.
    May 2011
    26
    66
    thanks ill check it out
    May 2011
    26
    66
    ok thats not it. i think.... lol theres oil leaking out of it but not alot. im starting to think its the rear main or the oil pan. pan will bee getting dropped this week i think so illl check it out but if not, what am i getting myself into with the main? i will be doing all the work myself. and motors gota stay in the truck. and its gota be done by 4:00pm the same day. possible????
  7. Remove Advertisements
