Coolant Temp sensor , no partnr findable
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, Coolant Temp sensor , no partnr findable in Cadillac Engine Discussion; Good evening all Caddy lovers! Dont know for sure ,if this is the right forum to post this engine related ...
    notease is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Fleetwood Brougham 1985 Moloney
    Sep 2011
    38
    106
    Dont know for sure ,if this is the right forum to post this engine related question ?
    I recently bought a Caddy DeVille 1980 Strecht Limo vehicle,
    On the front of the 368 6.0L Carb. engine is de the coolant temp sensor/coolant switch,
    with 3 wires (brown,green,blue), 1 goes to the dash i assume for the Engine Temp Light and 2 to some kind of chip/ecu
    for hot/cold running regoc.
    The sensor wires are hard wired to the sensor, so the new sensor does have to have the 3 wires and a pigtail connector on it.
    But the people here in The Netherlands cannot find the right partnr for it, i so do i.
    It and the manuals only come up with a 1 wire/connector coolant sensor for 1980 year. But it does def. 3 wires.
    Anyone got a clue and a partnr. ?
    Greetings out of cloudy Holland
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    Re: Coolant Temp sensor , no partnr findable
    You are not getting too much help here.. I am not up on the 1980 system... I know everything about the 81's.... If you could post some pictures and tell us what has gone wrong maybe we can help..
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Quote Originally Posted by notease View Post
    It's dark outside now, but I will look at my 80 cdv. tomorrow.
    Nov 2005
    3,013
    Quote Originally Posted by drmenard View Post
    Wouldn't an 81 basically be the same except for the 8-6-4?
    Nov 2005
    3,013
    I looked at my 80-368 and I will need a better description of location of this sensor, I cant see anything thats obvious, is it on vertical or horizonatal part of engine,
    what is it close to?.
  8. Remove Advertisements
