1957 Coupe 365 top end rebuild Do I need hardened valve seats?
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 1957 Coupe 365 top end rebuild Do I need hardened valve seats? in Cadillac Engine Discussion; I tore down my 365 engine this past week to discover a blown head gasket on the passenger side. The ...
    57coupe is offline Cadillac Owners Member
    Automobile(s): 1957 cadillac coupe deville
    Jul 2011
    Scottsdale Arizona
    3
    I tore down my 365 engine this past week to discover a blown head gasket on the passenger side. The heads will be redone but the issue I'm now presented with is whether I should have hardened valve seats installed. Maybe just the exhaust side? This car is driven on weekends and occasionally as a weekday driver as well.
    I'm trying to determine whether the stock seats can handle the rigors of unleaded/alcohol type fuels. Thanks for your comments.
    DouglasJRizzo is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 hearse, 1976 hearse
    Nov 2010
    Franklin Lakes, NJ
    53
    865
    Re: 1957 Coupe 365 top end rebuild Do I need hardened valve seats?
    If it were my car, I'd go for the hardened seats all around. It's not a big deal to do and will save you much grief and despair down the road. The biggest bugaboo for older engines today is modern fuel. As I've said elsewhere in this site, modern fuel is just not the same as the fuels were 40 + years ago.
    intragration's Avatar
    intragration is offline Cadillac Owners Fanatic
    Automobile(s): 1970 Coupe DeVille, 2002 Eldorado Collector Series
    Feb 2008
    Northlake, IL
    198
    Definitely do hardened seats. The other bugaboo for old cars is lack of zddp in modern oils. Make double-sure the oil you use has enough zddp for your flat tappet cam.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,177
    I would do the hardened seat , but I would also put in new stainless steel valves...If they are not SS now..
  7. Remove Advertisements
