472 Transmission question :(
Results 1 to 4 of 4
500, 472, 425, 368 Discussion, 472 Transmission question :( in Cadillac Engine Discussion; hi everyone, i have a 1969 coupe deville with a 472 and th400. long story short the th400 is 3 ...
    crazypiccasso17's Avatar
    crazypiccasso17 is offline Cadillac Owners Member
    Automobile(s): 1968 fleetwood brougham, 1969 coupe deville
    Jun 2011
    31
    1
    Exclamation472 Transmission question :(
    hi everyone, i have a 1969 coupe deville with a 472 and th400. long story short the th400 is 3 speed and i wanted to swap for a 4 speed. i was thinking of placing a 700r4 but am uncertain of fitment does anyone know which transmission will fit directly on the 472? any info will be most grateful thanks for reading
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,210
    Re: 472 Transmission question :(
    your 69 caddy is a heavy car.. The only OD transmission that I know of that will bolt to the cad block is th200 4r.... These are weak for what you want... They can be built to stand up , but will cost maybe $2000... the tail on the transmission is shorter and the driveshaft would need work...If I was doing it, I would not change the transmission... I would go to a high gear rear... and work the govenor to open up the shift points... On my car I have a 2.56 rear gears and changed the springs and weights{ they sell a kit} to get a 1-2 shift at 20mph and a 2-3 shift at 31 mph .. And that at light throttle... At heavier throttle those shift points can go way up.. A stock govenor can get you in 3rd gear before 15mph... If you really want over drive get a Gear vendors . that bolts to the back of your th400..... You won't break that...
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,027
    Use a TH700R4 with an adapter plate. Get one from a 90-93 Caprice/Fleetwood/Roadmaster. Those are the strongest ones, stock. You can build them stronger. You can't use a 94-96 because it is computer controlled.
    DouglasJRizzo is offline Cadillac Owners Enthusiast
    Automobile(s): 1975 hearse, 1976 hearse
    Nov 2010
    Franklin Lakes, NJ
    53
    865
    Quote Originally Posted by drmenard View Post
    I agree. The weight of the '69 Cad plus the huge torque output of the 472 is going to mush most modern AOD transmissions. The other solutions you mention are much more to my liking.
  7. Remove Advertisements
