| 500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines. | Cadillac Forums: cheap power improvements to the 425...
03-17-08, 05:22 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: cheap power improvements to the 425... I got a line on hopefully some 68 parts. How can I confirm that the intake and exhaust manifolds are truly the correct parts? |
03-17-08, 05:37 PM
|  | Cadillac Owners Member Cadillac(s): 1977 Coupe Deville | | Join Date: Mar 2005 Location: Louisville, KY | | | Re: cheap power improvements to the 425... Quote:
Originally Posted by BigPoppaD I got a line on hopefully some 68 parts. How can I confirm that the intake and exhaust manifolds are truly the correct parts? | I had this data in my spec lists - no guarantee that I have it right, but this manifold works on my car: 1605061 is a 472/500 stock cast iron with EGR – replaced 160955 stock 425 “negative rise” piece. I also had this from a web poster: ‘68-mid’70 engines used the first generation heat operated choke, with an exhaust passage around the front of the carb. These intakes have a cast rectangular box-shaped choke well. Mid’70-’73 engines do not have the heat passage around the carb, and have a round choke well with what looks like a freeze plug in the bottom of it. (This describes mine) Many ‘68-’70 engines also had no EGR valve. All OEM 472/500 intakes are dual plane. I surmise that I have a mid '70-'73 intake... I don't have the parts numbers for the exhaust manifiolds. You want those that have a nice thick front runner (by this I mean the exhaust tube for #1 and #2 cylinder). The ones to avoid are the stock 425 pieces which have huge dimples cast right in on both the left and the right front runner. |
04-14-08, 01:30 AM
| | Cadillac Owners Fanatic Cadillac(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green) | | Join Date: Mar 2006 Location: Western Massachusetts | | | Re: cheap power improvements to the 425... Wow! This post has a lot of history and a lot of info. There was someone selling crossmembers he manufactured for A bodies. The sugestion made here for the later C body looks good. Still available from GM?
ONe thing I thought of, You can change your cam's performance by adjusting cam timing by a couple degrees. You don't neccessarily have to give your money to a cam company for a mild timing change.
04-19-08, 12:45 PM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville | | Join Date: Feb 2007 Location: Maine Age: 48 | | | Re: cheap power improvements to the 425... Hey djcwardog, do you have any timeslips yet? Please let us know how the mods worked out. |
04-17-09, 07:48 AM
| | Cadillac Owners Fanatic Cadillac(s): '85 FWD fleetwood, '93 fleetwood Bro | | Join Date: Mar 2009 Location: mich Age: 78 | | | Re: cheap power improvements to the 425... The after market cam guys like Comp Cams advise advancing the cam timing by like 4 degrees for low-end power, and retarding the timing by about 4 degrees for higher RPM power. There is no magic power boost in fooling with cam timing in general. Most folks install new cams "straight up", meaning the timing marks on the cam drive sprockets are lined up like an overhaul manual specifies, as opposed to setting it up with a degree wheel etc, for getting all available power. |
10-11-09, 01:12 AM
| | Cadillac Owners Fanatic Cadillac(s): 79 coupe deville d'elegance (76k og), 84 coupe deville | | Join Date: Aug 2007 Location: Black River Age: 24 | | | Re: cheap power improvements to the 425... |
10-16-09, 04:00 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: cheap power improvements to the 425... Hello i buy a 2115 edelbrock intake for my 79" 425 cid coupe.
What gasket sal i take the edelbrock?
Or can i take a splasch pan a 425 or a 472?
I like splasch pan the intake are not too hot to.
thanks for your recomendations.
greeting Danny from holland (europe) |
10-18-09, 04:45 PM
| | Cadillac Owners Fanatic Cadillac(s): 79 coupe deville d'elegance (76k og), 84 coupe deville | | Join Date: Aug 2007 Location: Black River Age: 24 | | | Re: cheap power improvements to the 425... anyone have a price range for the intake? had someone tell me 200+ shipping on a 500 intake and 50+ shipping on the ac compressor bracket. a little much with shipping. picked up a caprice sway bar to switch over. just need a couple more goodies. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
