Belt size needed after removing smog pump on 472 ?
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, Belt size needed after removing smog pump on 472 ? in Cadillac Engine Discussion; I own a 1973 Coupe DeVille with a 472. I'm wondering if anyone knows what size belt I would need ...
    JRG73 is offline Cadillac Owners Member
    Automobile(s): 1973 Coupe De Ville
    Feb 2010
    32
    11
    I own a 1973 Coupe DeVille with a 472. I'm wondering if anyone knows what size belt I would need in order to bypass the smog pump.
    Thank You!
    -James
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    Re: Belt size needed after removing smog pump on 472 ?
    You can't just take off the smog pump... One belt goes around the crank , waterpump and smog pump... another goes around the waterpump[on a different pulley] and the Alt. ... If you take off the first one nothing turns the waterpump ... waterpump not turning means Alt. not turning... The only year bottom crank pulley , 1970, would let it work... it was the only year with 2 belts to the a/c comp and PS and one belt for the Alt. .. Complete pulley set-ups from 76 to 79 can be used ... they must have no smog pump... but the A/C and PS pulleys would also have to be changed...you could call MTS and see if he a 1970 crank pulley...
