What size fitting goes into the Rochester carb on 472 for fuel line?
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, What size fitting goes into the Rochester carb on 472 for fuel line? in Cadillac Engine Discussion; Mine is completely unusable. Need to get a new one for new (rebuilt) carb. Anybody ? '74 Caddy....
    73super is offline Cadillac Owners Member
    Automobile(s): 1974 Sedan Deville
    Jan 2011
    13
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: What size fitting goes into the Rochester carb on 472 for fuel line?
    This fitting is pretty common on Rochesters and should be available at any parts store. Just ensure you get the correct fitting for your application. As you don't describe the problem, I can only guess. Did they forget the seal that goes into the recess at the end of the fitting?
    Jan 2011
    13
    Can't tell you as it was impossible to remove. And I TRIED EVERYTHING.. Have no idea how that happened.. it's almost like it "bonded" itself to the carb. I'm installing a rebuilt carb and had to cut the line to get the carb off. Never had this much trouble before.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Since you have the line cut it will be a good place for an in-line filter. You can buy a new short piece of gas line with the fitting already on it. It may have a fitting on each end and you will have to cut one end off.
    Jan 2011
    13
    Yep.. I was planning on installing a gas filter right there.. you read my mind.
    Anxious to get this mighty 472 up and humming!
    Mar 2006
    1,493
    It is a common problem that the fuel line fitting freezes to the inlet nut. Normally, you use a 1" wrench on the nut and a 5/8" line wrench on the fitting, provided the fitting hex isn't rounded out. There have been times when the aid of a propane torch to heat the fitting has assisted removal. Smack the wrench on the fitting. A sharp rap often will break the fitting free, rather than constant pressure.
  9. Remove Advertisements
