A.I.R. Pump/ Smog Pump on a 6.0 368/ Federal Emission
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, A.I.R. Pump/ Smog Pump on a 6.0 368/ Federal Emission in Cadillac Engine Discussion; Hey, Currently my car is making a weird noise like a rumbling sound and light knock and I've been told ...
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    Hey,
    Currently my car is making a weird noise like a rumbling sound and light knock and I've been told it's the A.I.R. / Smog pump. My question is can I just remove the belt and run it without the belt driven it? If so, would that have any affects on my engine? Decrease horsepower, lack of acceleration?
    I've checked with my service manual it seem like an easy job to replace but in the mean time can I just remove belt to eliminate the noise?
    Thanks
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: A.I.R. Pump/ Smog Pump on a 6.0 368/ Federal Emission
    Yes, you can. If your state's inspection requires it to be driven, you can open the pump and pull out the vanes.
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    39
    1,150
    thanks, here my car no longer goes through the state emissions only safety. Once my car hit 25 I removed the catalytic converter and muffler and ran dual exhaust.
    I'll, just in the mean time, remove the belt and go from there.
  5. #4
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,169
    If I remember right if you take off the AIR pump belt it will stop the waterpump and alternator...If you want to get rid of the pump and all the junk that goes with it... Get the crank and waterpump pulleys off a 77-79 caddy with a 425 motor...then you can run with 2 belts... and you could get the alt. bracket off the 425 and use that ... that will make it look alot neater....Now if you want a little more free power... take off the exhaust manifolds and Y pipe off that 425 and put those on.. If you do that ,you will have to leave off the plate that goes between the head and exhaust manifold...
  6. #5
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    39
    1,150
    Quote Originally Posted by drmenard View Post
    actually no it won't, and no don't want to get rid of the pump and the junk that goes with it. it's there for a reason and my car has ran fine the 11 years I have owned it..I'm running straight dual exhaust so why would I need the exhaust manifold and Y pipe?
  7. #6
    May 2003
    Massachusetts
    1,169
    Well if you got duals on it now its been opened up already... If you removed the cat already , what good is theAIR pump doing? The pump is to pump air into the exhaust to help burn the unburned fuel in the cat... Its just one more thing spinning around to rob you of a little more power... I've got a almost new AIR pump if you need it...
  8. #7
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    39
    1,150
    you know i was wrong and you were right....today i loosend the alternator and removed the belt, then I removed the 3 bolts that bolt the pulley on to the air pump and removed that belt. I reinstalled the belt and tighten the alternator and turned on the car and yup....the alternator is not turning but in removing the pulley off the air pump and while car was running it eliminated the noise so for sure it's the air pump...so while at the JY when I went; I got the air pump off the 80 donor car for $13.50 so hopefully that one is good!
    How much you asking for the "almost new" air pump?
    Talk to you later
  9. Remove Advertisements
