425 Oil Pan Problems
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, 425 Oil Pan Problems in Cadillac Engine Discussion; I purchased a 1966 deville that has a 425 motor from a 1977 deville inside of if. It runs good ...
    dbird35 is offline Cadillac Owners Member
    Automobile(s): 1968
    Jul 2009
    39
    13
    I purchased a 1966 deville that has a 425 motor from a 1977 deville inside of if. It runs good but the problem that I'm having is the Tie Rod that goes across is rubbing and digging into the oil pan:-((( My question is can I take a oil pan from a 429 or a 472 and fix my problem? If anybody have a good solution it would be greatly appreciated.......
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,187
    Re: 425 Oil Pan Problems
    The pans are not the same for those motors.. The only pan you might have a chance of working would be a 68-74 RWD 472 pan or a 75-76 RWD 500.. There are alot of these around for cheap.... If they don't work , they might need a little mod...
