Visual differences in 472 vs 500
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, Visual differences in 472 vs 500 in Cadillac Engine Discussion; hey everyone, new to the board. Anyone know a way to visually tell if an engine is a 472cc versus ...
    DaGriff is offline Cadillac Owners Member
    Automobile(s): 1970 DeVille Convertible
    Sep 2010
    48
    13
    Anyone know a way to visually tell if an engine is a 472cc versus a 500cc?
    thanks for any info you can give me.
    -joe
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    381
    Re: Visual differences in 472 vs 500
    The 68/69 472s have a different block#. The best test of 70-76 is check the stroke. The 70-74 Eldo is 500 (special pan); all 75-76 (except Seville 350) are 500. Bruce Roe
    Sep 2010
    48
    13
    Hey Bruce, thanks for the info,
    I've got a 70 DeVille convertible I just got. Over the years, and past owners, things got changed...paint color, interior color and trim don't match the numbers. My valve covers seem to be different from other 70 DeVilles I've seen, but they seem to match those I've seen on Eldos. On my car the driver's side valve cover has a PCV vent hole that is on the side of the valve cover facing the carb. On the other DeVille's i've seen the vent hole has been on the top of the valve cover facing outward. I just thought maybe some changes were made with the engine as well. I was looking for some visual clues without digging into the engine. I read somewhere on the internet that the 472 had a front sump oil pan and the 500 had a rear sump oil pan.......don't know if this is true or not. And also, maybe this could be swapped as well. Thanks for the reply.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    To find out what you really have... Start with the block number and the casting number on the heads.. the number on the heads is under the rocker cover... this won't tell you if its a 472 or a 500 , but it can give you a idea of what year it is and if someone put in a 425 in there... does it have a EGR valve?
    Sep 2010
    48
    13
    Thanks for the reply drmenard. it doesn't look like i have an EGR valve.
    May 2003
    Massachusetts
    1,181
    So if it is a no on the EGR, looks like it could be a 1970 intake... the 1970 motors had some 1970 only things... they had no air pump and no air tube or holes drilled in the heads...they had 2 compressor - P/S pump belts and one alt belt... if yours has these things changes are it is a 1970 motor...
  9. Remove Advertisements
