Overdrive for a '79 425?
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, Overdrive for a '79 425? in Cadillac Engine Discussion; Did Caddy ever mount a 700r4 to the big blocks? I just put a 425 into a Jeep truck and ...
    jaber is offline Cadillac Owners Member
    Automobile(s): '79 425 engine/'75 Jeep
    May 2010
    4
    I just put a 425 into a Jeep truck and was wondering what my options would be as far as getting an OD that has the Caddy BB bell. If they did use a 700, I could swap tail shafts and still use a t-case on it.
    If anyone has any info, I would greatly appreciate it.
    Thanks in advance.
    Jeff.
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    366
    Re: Overdrive for a '79 425?
    The 425 ended production in 79, with a THM400 trans. Bruce Roe
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    I believe the 700r4 was used briefly behind the Olds based diesels in pick-ups. They didn't last, cause the owners were replacing them with TH400s.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Advance adapters used to make an adapter for that (BOP to Chevy)
    May 2010
    4
    Quote Originally Posted by deVille33 View Post
    Thank you for this. It gives me hope....
    I will repost if I can find out for sure.
    nickinvegas777's Avatar
    nickinvegas777 is offline Cadillac Owners Member
    Automobile(s): 1978 De Elagnce coupe
    Jun 2012
    45
    1
    wow lots of caddy guys could use this info,
    i am going on a hunt tomorrow what year of truck would you say maby 81 to 84 ?
    chevy gmc diesel ? i so want a 700r 4 in my 78 coupe!
    ferrisworld is offline Cadillac Owners Fanatic
    Automobile(s): 1979 Sedan Deville
    Feb 2005
    Sacramento, CA
    444
    If you want a manual there's a bop bellhousing available for the t56.
    Feb 2007
    Maine
    55
    3,310
    I don't think those diesel trucks had 700r4's. I worked on my father in laws enough that I should remember but not quite. His either had the plain old th350 or possible the 200r4 like all the ninety eights and Cadillacs. Any Jeep engine swapper should be familiar with Advance Adapters. They can put almost any trans behind almost any engine.
  11. Remove Advertisements
