Dual exhaust on a 368 w/ DFI
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, Dual exhaust on a 368 w/ DFI in Cadillac Engine Discussion; I recently got a 1980 Seville(w/ the 368) for free. The guy just wanted it out of his driveway. The ...
    tmoore8828 is offline Cadillac Owners Member
    Aug 2004
    7
    I recently got a 1980 Seville(w/ the 368) for free. The guy just wanted it out of his driveway. The car fired up as soon as I charged the battery. I did all the basics, oil change, plugs, cap/rotor, wires, transmission fluid, fuel filter etc... The car ran, but pretty poorly. I ran the diagnostics and determined the computer was dead. I replaced the computer ($102 for a reman) and it was the difference between night and day! Now for the question. The stock exhaust is shot from the Cat back. I have a friend that specializes in custom exhausts. How would the computer react to a true dual exhaust with an x or H pipe. I did some searching on the sight and read some posts where people stated the stock fuel system pressure was too low to keep the engine from leaning out. What do you guys think? Thanks in advance Tom
    TorqueInc's Avatar
    TorqueInc is offline Cadillac Owners Member
    Jul 2004
    90
    Re: Dual exhaust on a 368 w/ DFI
    a dual exhaust will make it VERY lean...its been done
    Aug 2004
    7
    Is there any way to avoid the lean condition??
    TorqueInc's Avatar
    Jul 2004
    90
    Not that im aware of i havent messed with the factory FI systems enough to have a fix.
    maybelline is offline Cadillac Owners Member
    Automobile(s): 1983 Coupe De Ville
    Feb 2012
    49
    1
    Just to add to the knowledge base. If a person increased the fuel pressure the injectors would flow more. add an aftermarket fuel pump to boost pressure and a fuel pressure reg that operates on manifold vacuum (like from FAST.) and you have a pretty simple solution to the problem. I don't know much about this particular engine but i assume it has an O2 sensor. If it does, the computer will be able to handle the added flow with no problem.
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    381
    I don't think duals will hurt much; don't expect spectacular performance.
    I believe the car has an OX sensor which will compensate automatically.
    Bruce Roe
    drmenard is online now Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,183
    I had a DFI 368 that I put on 425 exhaust manifolds and Y pipe and cat on... The rest was stock. It made a big difference and I had no problems... If I thought it was running a little lean I would just adjust the fuel pressure regulater up a few lbs...I bet, like Bruce said, the O2 sensor will take care of it...
  10. Remove Advertisements
