noisey lifters
Results 1 to 3 of 3
500, 472, 425, 368 Discussion, noisey lifters in Cadillac Engine Discussion; I have just fitted new valve lifters and oil pump .I have oil coming up to the rockers but was ...
    ozzy rick is offline Cadillac Owners Member
    Automobile(s): 1978 fleetwood formal limo
    Jul 2010
    56
    1
    noisey lifters
    I have just fitted new valve lifters and oil pump .I have oil coming up to the rockers but was slow and lifters are noisey
    There was a problem with low oil to top of engine and one crook lifter which prompted me to fit new parts
    could there be a problem with pick up that would cause this
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: noisey lifters
    If you are concerned about the oil pressure it would probably worth it to hook up a real gauge to verify it. It does take a long time for the oil to get to the rockers but since the oil is up there now it should be ok.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: noisey lifters
    Most mechanics will pre fill lifters by putting them in a jar of oil and depressing the check valve repeatedly to fill, THEN install them. New lifters on an old cam require the engine be started and let run for 15 to 20 min. at fast idle to wear in the lifters to the cam. Dry lifters might take an hour or more to fill.
