V-belt adjustment 472 1974 One is more loose than the other
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, V-belt adjustment 472 1974 One is more loose than the other in Cadillac Engine Discussion; I have read that the belts need to be tightened until there is 5/8in of play in between the pulleys ...
    YourMainParadox is offline Cadillac Owners Fanatic
    Automobile(s): 1974 Cadillac Hearse 472
    Apr 2010
    493
    I have read that the belts need to be tightened until there is 5/8in of play in between the pulleys on the center of the belt. Is this correct for our cars? Also the power steering/compressor and crank uses the 2 belts to do the same job. The outer belt (closest to the grill) is a fair amount looser than the inner belt (closer to the engine) no matter how I adjust it. How do I solve this problem? Is there an adjustment that I am missing?
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: V-belt adjustment 472 1974 One is more loose than the other
    Only way is with two new belts, unless one new one will match one of the old ones for length and tension.
    Chance are, it will be fine the way it is, and the tighter belt may stretch a bit later on.
    Apr 2010
    493
    these are brand new belts. Even the old ones I just changed had the same issue
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,178
    Belts should be bought as a matched set...
    Apr 2010
    493
    they are identical belts purchased at the same time from the same place.
    The old belts had the same issue where the outer one was looser than the inner one.
  8. Remove Advertisements
