76 eldorado fuel injection
Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By BRUCE ROE
500, 472, 425, 368 Discussion, 76 eldorado fuel injection in Cadillac Engine Discussion; I have a 76 eldorado fuel injection, it runs rough on cold start, blows black smoke, runs rich, for a ...
    dpoulin17 is offline Cadillac Owners Member
    Automobile(s): eldorado
    Jun 2010
    54
    I have a 76 eldorado fuel injection, it runs rough on cold start, blows black smoke, runs rich, for a couple of minutes then runs great, I changed the injectors,but still have problem,, any ideas,,, thanks Dave
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,176
    Re: 76 eldorado fuel injection
    There is a board member, Bruce Roe, that I believe knows these systems better than anyone.. If you have something wrong with your computer, he's the man to fix it.. But first check your two temp sensors... Unplug them and check the resistance with a ohm meter.. with everything cold they should read about the same, within a few hundred ohms.. If they check open,they are bad.... I have some of these sensors....I believe the coolant sensor is in a hose that comes off the passanger side head at the firewall.. The air temp sensor is in the intake, its on the passanger side , rear of the intake... But you could have a bad map sensor, thats in the computer or could be a leak in the hose going to it..
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    375
    I would start by checking the temp sensors, which fail often. However, that doesn't sound like a temp sensor. It could be a bad ECU, perhaps the MAP sensor (located inside the ECU). Having a backup makes swapping ECUs a good test procedure. No charge for testing an ECU if you send it here.
    Make sure the vacuum line from the throttle body to the ECU will hold a vacuum. A leak will make it rich. You could pinch the hose on the fuel return line. If it doesn't get richer (more fuel pressure), the pressure regulator has a problem. See a wiring diagram for your ECU and some other stuff is in several ALBUMS of my PHOTOBUCKET. Bruce Roe
    http://s93.photobucket.com/albums/l71/bcroe/
    (that is a lower case "L"71, not an upper case "i"71)
    click on an Album
    click on a picture to enlarge + description
    70eldo and the APEMAN like this.
    eliyahu is offline Cadillac Owners Member
    Automobile(s): 1976 Eldorado Convertible
    Sep 2013
    52
    so, where can I find the air-temp sensor and water temp sensor to replace failed ones?
    Eli
    May 2003
    Massachusetts
    1,176
    I have them for sale..
    Jun 2009
    375
    Quote Originally Posted by eliyahu
    where can I find the air-temp sensor and water temp sensor to replace failed ones? Eli
    I have seen them on Ebay, and Maximum Torque Specialties sells new ones. Bruce Roe
    May 2003
    Massachusetts
    1,176
    I have sent him one to get him going.. MTS has them for $110 each
    Jun 2009
    375
    If you only have one good sensor, make sure its the one in the coolant. It has
    far more effect than the one in manifold air. Bruce Roe
    Feb 2003
    california
    69
    6,633
    You can swap the air sensor for the coolant temp sensor, same part number! to see if the cold start changes. By that, I mean better or worse. Bruce knows his stuff!
    May 2003
    Massachusetts
    1,176
    Eli emailed me today , he got the sensor I sent him and he will be putting it in soon.. Hope he posts his results...
    mc1958 is offline Cadillac Owners Member
    Automobile(s): 1975 500
    Oct 2015
    58
    1
    I have a 1975 Cadillac 500 with a good running EFI set up I had Bruce Roe check out my ECU,Willing to sell all the injection complete as a unit you can here it run I won't remove it tell it is sold you can contact me at 530-517-0537 my name is Mike and I'm in California Thanks ..
  14. Remove Advertisements
