1978 Early Fuel Evaporator EFE
Results 1 to 7 of 7
500, 472, 425, 368 Discussion, 1978 Early Fuel Evaporator EFE in Cadillac Engine Discussion; HELP. I have a 79 Cadillac with 425 and a cold start issue - rebuilt carb and new choke with ...
    charcoll is offline Cadillac Owners Member
    Automobile(s): 77 cadillac
    Mar 2010
    13
    HELP. I have a 79 Cadillac with 425 and a cold start issue - rebuilt carb and new choke with the same issue.
    I suspect that it is the EFE valve but need to provide my mechanic with details.
    Does anyone have info on troubleshooting this or a diagram?
    Is this part still available or can it be de-activated?
    Please advise.
    Thanks,
    Charcoll@yahoo.com
    gornati's Avatar
    gornati is offline Cadillac Owners Fanatic
    Automobile(s): 1978 Coupe DeVille
    May 2004
    Brazil
    40
    313
    Re: 1978 Early Fuel Evaporator EFE
    Quote Originally Posted by charcoll View Post
    Please advise.
    Thanks,
    Charcoll@yahoo.com
    i have the vacuum diagrams... is that what you need?
    Mar 2010
    13
    Actually, I found them in a '77 shop manual - Not much in diagnostics on this part but I'm optimistic - My concern is that if it is not that and not the carb since it was re-built and other things are relatively new what else is there? Cold start problems shouldn't be this difficult - however, this is not drivable untill fully warm.
    Thanks for your help.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Are you sure the vacuum lines are routed correctly and that you have signal? There shouldn't be signal to the dashpots until youv'e attained operating temperature. Have you checked your choke settings? There is a description of the proceedure in the manual and if you follow it, your carb should respond correctly.
    Timing set correctly?
    Mar 2010
    13
    Vaccum lines are good - choke is good - I do need too check the signal - you are right though this is controlled by the TVS - my fingers are crossed that this will narrow it down. I wonder if it turns out that the valve is bad if replacements are available.
    Mar 2006
    1,493
    Are Your dashpots holding vacuum? If there is a crack in your vacuum advance canister's diaphram, your engine will stumble on excelleration off the line and pick up will be slow until the centrifical advance kicks in. No vacuum or a cracked diaphram on your chke pull-off dashpot will hold your choke closed longer than it should.
    Mar 2010
    13
    Testing it all out this weekend - thanks for the tips
  10. Remove Advertisements
