68 sedan deville 472 project
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, 68 sedan deville 472 project in Cadillac Engine Discussion; Hello! newbie from Finland is writing.. I have 68 sedan deville(non-ht) with 472 engine. Doing overhaul for the engine and ...
    JiipeeH is offline Cadillac Owners Member
    May 2008
    11
    Hello!
    Doing overhaul for the engine and for the whole front of car(suspension,steering etc).
    I have to overbore(.030") my block, Question is which piston I should use?
    I dont want low compression ratio, since compression is not a problem, we only have 95/98/99 octane gasoline in Finland. Gasoline prize is 6.5$/gallon
    I dont care how much is mpg... since this car is a hobby car, not a car I use daily.
    I already have forged I-beam rods(ebay ~200$, chinese crap.. ) with arp bolts. Not a bushed full floating style.
    So, from flashcraft RC cast pistons with 10.5:1 compression ratio or Keith black 472 pistons? KB has lower compression ratio -> how much I will loose hp/torque?
    Other things: I have planned to put a mts #10 cam+lifters, new springs, oversize valves, flashcraft stage III adjustable shaft rockers, 902 76cc heads, headers with dual exhaust(no x- or h-pipe), hi-volume oil pump, cloyes timing set, hei/msd ignition etc.
    Let me show some pictures:
    front comparment, broken piston, rod journals
    edit: those scrap dual exhaust which are on photo have gone to trash bin.. not mine job..
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: 68 sedan deville 472 project
    JiipeeH,
    Hi and welcome. I'll address the points you mentioned on a point by point basis.
    Why did you go with these? You state questionable quality. New / Used? Why not original rods?
    If you question the strength of the rods, send them to a shop and have them maged and rockford tested.
    Are either of these hyperutechic or high silicone cast pistons or forged?
    Make sure your valve lift / valve size / cylinder head selection will allow clearance with whichever pistons you select.
    May 2008
    11
    My rods are these:
    http://cgi.ebay.com/ebaymotors/ws/eB...m=220608317389
    So, should I use original rods instead?
    I read on many places that 472/500 rod etc. are not designed to handle over 4000 rpm ?
    Mar 2006
    1,493
    Stock rods could handle over 4000 rpm, but not for extended periods and most likely not on a daily basis. Depends on the weight of the piston. Not familiar with the rods you have. If they are all they advertize, they should be an improvement over stock rods. That said, they don't give you much. No assurances, guarantees, ratings, or recommendations.
    Mar 2006
    1,493
    Here's an outline from a Hotrod article on the build of a performance 500.
    505-Inch Pump-Gas Cadillac Engine - Full-Frontal Cadillac
    BY THE NUMBERS
    TORQUE INC. 505CI CADILLAC
    Bore: 4.320-inch
    Stroke: 4.304-inch
    Displacement: 505 cubic inches
    Compression ratio: 10.5:1
    Camshaft: DRC solid flat-tappet
    Cam duration: 258/258 degrees
    at .050-inch tappet rise
    Valve lift: . .630-inch
    Rocker ratio: T&D 1.8 ratio shaft rockers
    Lobe separation: 112 degrees
    Installed centerline: 110 degrees
    Top ring: .043-inch Speed Pro barrel face
    Second ring: .063 Speed Pro scraper
    Oil ring: 3mm
    Piston: Diamond center dish forged
    Block: OEM Cadillac 500
    Crankshaft: OEM Cadillac 500
    Rods: Scat/MTS 7.000-inch H-beam
    Main journal: 3.240-inch
    Rod Journal: 2.490-inch
    Cylinder head: MTS/Bulldog
    Intake valve diameter: 2.250-inch
    Exhaust valve diameter: 1.860-inch
    Intake manifold: MTS/Bulldog single-plane
    Carburetor: CSU modified Holley 1050 Dominator
    Header: Fab Shop 2-inch primaries;
    3.5-inch merge collector
    Ignition: ICE Ignition 10 amp
    Damper: MTS
    Water pump: MTS/Torque Inc.
    On The Dyno Dts Dyno Data Torque Inc. 505CI Cadillac
    Of course this is for a 500. Got this from another post 4 pages back, There is another on the same page regarding the single engine land speed record machine. It is interesting, but has few details regarding engine internals.
  8. Remove Advertisements
