HEI distributors identification help needed
Results 1 to 10 of 10
500, 472, 425, 368 Discussion, HEI distributors identification help needed in Cadillac Engine Discussion; Someone offered to give me some HEI distributers that they said would fit my car but they are both different ...
    YourMainParadox is offline Cadillac Owners Fanatic
    Automobile(s): 1974 Cadillac Hearse 472
    Apr 2010
    493
    Someone offered to give me some HEI distributers that they said would fit my car but they are both different slightly and are unknown to be working or not. I have the only numbers here:: (1112940 6610) and (1103246 6m22). Does anyone know what these came from and if they will fit my 1973 Cadillac 472? What other ones would fit if these won't?
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: HEI distributors identification help needed
    My distributor, a '76 500 is # 1102354, the last year of the 500 engine. Seems like the one you have with #1112940 would be a later one. What are the differences you noted?
    If you have a distributor now, to compare them with, you may be able to figure out if one of those will work for you. If yours is the points type, the double belt system will be in the way of an HEI distributor, so you will have to remove the inside belt or change pulleys etc. That has been covered here before.
    As far as not working, they are simple inside, and parts are not very expensive.
    Apr 2010
    493
    I would have to drive way out and pick them up. He said they came off of a race car so unknown on which v8 they came from.
    Apr 2010
    493
    What are the other options besides going to an HEI?
    Mar 2009
    mich
    85
    728
    You might be better off going to an auto salvage yard and getting a later HEI,like '75 thru '76. Mallory has one and MSD has one, but expensive, for a stock engine. Can't remember when HEI was standard on the Caddy engines, '75 on Chevys.
    If you have double belts, the inside one wont clear the HEI distributor, and I believe you can simply remove it. Folks here know more about that.
    Apr 2010
    493
    Do I have to change out anything else to go to the HEI distributor?
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    381
    A points ignition has a resistor or resistor wire (several ohms) in series with the 12V feed to the coil. That resistance must be removed for an HEI. Bruce Roe CLC # 14630
    Mar 2009
    mich
    85
    728
    Like Bruce said, you need to get 12 volts to the HEI distributor, and not use the wire that's powering the point type distributor.
    On the fuse block under the dash there will be places that have power when the ignition is on (switched power) and you can usually tap in there with a spade connector and run the wire from there to the HEI. Auto stores usually have the HEI power connector for the distributor.
    Apr 2010
    493
    No salvage places around here have these old 472 and 500s. What are the part numbers for those HEI units? There are some neat ones on ebay like http://cgi.ebay.com/ebaymotors/ws/eB...11323780995027 BUT the guy said this would not fit
    Brother_B's Avatar
    Brother_B is offline Cadillac Owners Fanatic
    Automobile(s): 1969 Coupe DeVille, 1972 Sedan DeVille
    Jan 2007
    Neptune Beach, FL
    44
    159
    I went to HEI on my '69 472, and kept the double belts, it's very close, rubs a little, but I thinks it's OK, although I don't run the AC... yet. I got a DUI HEI distro. It's probably better to somehow move the double belts out a little or go to single belt, but might not absolutely be required.
  13. Remove Advertisements
