Remove 472
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, Remove 472 in Cadillac Engine Discussion; First post. removing 472 out of my 69 fleetwood. Need simple instructions. Have a manual,says keep tranny and engine together ...
    69 hearsedriver is offline Cadillac Owners Member
    Automobile(s): 69 m$m hearse combo
    Apr 2010
    Steeler Country
    46
    3
    TalkingRemove 472
    Have a manual,says keep tranny and engine together for removal. A friend says take them apart,they are easy to put back together. My plan is to remove and clean and new gaskets,hoses,paint. The engine runs! I am not a mechanic but i am mechanicaly inclined. Any easy tips or tricks would be appreciated. My main concern is the trany/engine separation. Will the tranny fall to the floor or will the support hold it? Thanks for any help!
    I have had the car, apart, for 9 years and i am finally digging in.
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    381
    Re: Remove 472
    I always remove the engine by itself. It takes a support for the trans, and another for the engine when its unbolted from the trans. Bruce Roe CLC # 14630
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: Remove 472
    You can do either. It is sometimes difficult to remove both together, because you have to have clearance for the trans tailsection.
    If I separate engine / trans, I support the trans on a floor jack ( I don't have a trans jack, but they are a nice tool to have, you might be able to rent one ). If your working on the floor, it helps to have another body to assist you. When you separate the trans from the engine you have to wrestle with it to balance it on the jack and that TH400 is one heavy trans. You don't have to do this with a trans jack.
    Here's a tip. After you have disconnected the torque converter to flex plate bolts, replace the dust shield. This will keep the torque converter from falling out and dousing you in trans fluid.
    Once you,ve separated engine and trans, the engine is now suspended on the engine mounts. It's a good idea to have the engine hooked to whatever your using to pull the engine, then you can take the weight off the mounts, if you plan to save them.
    LvVein is offline Cadillac Owners Member
    Automobile(s): 69 DeVille convertible
    Mar 2010
    31
    3
    Re: Remove 472
    I'm actually in the middle of doing this right now and I was wondering... where do you guys attach the chains to? I'll be pulling the engine and trans together.
    Mar 2006
    1,493
    Re: Remove 472
    Quote Originally Posted by LvVein View Post
    The 425 had U straps from the factory. Not sure the 472 had them.
    If I pull an engine and there are no factory provisions, I pull a manifold bolt at the rear corner and another at the opposite bank at the front of the engine. Bolt a speader or a chain length between the two and hook to that.
    If you use a chain, put a long bolt or rod on either side of the hook to keep things from slipping. I sometimes use a old push rod against the force side ( loaded side ) of the hook. Finding the proper balance point is a matter of trial and error, unless you have the spreader bar with the adjustable center point.
    ScottConklin's Avatar
    ScottConklin is offline Cadillac Owners Member
    Automobile(s): 64 Coupe Deville 78 Eldorado 85 Seville 94 Fleetwood
    May 2010
    Indiana
    52
    48
    Re: Remove 472
    Get a intake-mount lift plate. They are cheap and in conjunction with a leveler on the hoist make pulling the motor a helluva lot easier and safer. For both you and the engine. It's good to have the carb off anyway when yanking one. I've screwed up more than one when a chain slipped or pulled tight where I thought it wouldn't and cracked or just warped the carb body/linkage/etc.
  9. Remove Advertisements
