Engine will not turn back on if hot - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 52 of 52
500, 472, 425, 368 Discussion, Engine will not turn back on if hot in Cadillac Engine Discussion; The MAP test point should read at least 7V with the engine not started. Getting that replacement ECU might solve ...
  1. #46
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    386
    Re: Engine will not turn back on if hot
    The MAP test point should read at least 7V with the engine not started. Getting that replacement ECU might solve the problem. Then you can get the first one fixed as backup. Bruce Roe
  2. #47
    gornati's Avatar
    gornati is offline Cadillac Owners Fanatic
    Automobile(s): 1978 Coupe DeVille
    May 2004
    Brazil
    40
    313
    do you have a replacemente ECU?
    can you sell me one of the MAP replacements?
  3. #48
    gornati's Avatar
    May 2004
    Brazil
    40
    313
    by the way, your inbox is full..
  5. #49
    gornati's Avatar
    May 2004
    Brazil
    40
    313
    well Bruce, the point is i rather go spending $50, with you than 500 in a new remanufactured ECU from NAPA online.
    Please if you can, please sell me one with a little bit of instructions i can make it work.
    Thanks
  6. #50
    Jun 2009
    386
    You ought to try bcroe@juno.com . I might finally have figured out how that Cad in box works. I could send a MAP sensor, but its a worry that it won't get installed properly, or here could be additional problems. I like to completely check the ECU on my tester. How come you changed your mind about the NAPA ECU? Bruce
  7. #51
    gornati's Avatar
    May 2004
    Brazil
    40
    313
    I rather send you my ecu and you do the job, I will email you today!
    I think napa is charging way too much for those, let's not forget that they also charge a extra $84 for core.
    And I can't purchase online, I would have to wait until november and go personaly to a store.
  8. #52
    gornati's Avatar
    May 2004
    Brazil
    40
    313
    Ok, problem FIXED...
    Turns out that, no problem in the vacuum lines, no problem in the timing chain or sprokes...
    Bruce Roe was dang right!
    Problem was only the ECU, i sent him the module, 10 days later i receive it back, just plug it and voila!!! Everything worked as is supposed to work.
    Bruce Thanks very much!!! was the best spent money ever!
    This guy is good!!!
    cheers bruce!
  9. Remove Advertisements
