425 Valve cover gaskets
Results 1 to 10 of 10
500, 472, 425, 368 Discussion, 425 Valve cover gaskets in Cadillac Engine Discussion; I recently bought a '78 Deville 425-------my mechanic says it needs new valve gaskets,they are leaking a bit---he wants $250 ...
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    I recently bought a '78 Deville 425-------my mechanic says it needs new valve gaskets,they are leaking a bit---he wants $250 including labor.I could do them myself but passenger side cover has an AC line running directly over 1 end of it.
    Might be a real hassle doing it myself.
    Anyone here ever changed their own VC gaskets on a 425? If so---can it be done by a do it yourselfer?
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,182
    Re: 425 Valve cover gaskets
    I don't think a cadillac dealer would charge that much.. To me thats a very eazy job... but you have to have some tools and skills...Getting good rubber gaskets will insure it won't be leaking again anytime too soon..cork gaskets are not good here... I always clean the covers so there is no oil atleast where the gasket sets... then I put RTV on the cover to glue the gasket to the cover and let it dry for a hour...make sure the head is clean where the gasket hits it... it is very eazy to over tighten the covers, check torque..
    albymangled's Avatar
    albymangled is offline Cadillac Owners Fanatic
    Automobile(s): 1970 calais coupe
    Jan 2010
    Adelaide Australia
    57
    343
    If you have simple hand tools then take your time (you're not charging yourself by the hour..) have a good look at what needs to be done and save your self around $230....
    I dont find it a hard job.
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    If you could get a picture of the cover with the line running over it, and post it, maybe the folks here could offer more advice. Like if the line comes from the AC compressor, maybe un-bolting the compressor would help get some slack in the line etc.
    Jan 2010
    Adelaide Australia
    57
    343
    ok guys...did the google image search bit and came up with these....I hope they provide some enlightenment
    I can see how the A/C line could be a nuisance but ya still should be able to get the job done.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    The best way would probably be to unbolt the A/C compressor and move it out of the way.
    Jan 2007
    1,673
    Quote Originally Posted by albymangled View Post
    Thanks much for taking the time to find some pics! I WISH my engine looked as pristine as the one in the pics.
    I had some time yesterday and took a close look at my valve covers-----i found many of the bolts holding them on were loose---so i gently tightened them,just snug.
    Sure is much more room to work under the hood of my '78 SD than my '95 SD.
    Plugs are in plain view and much room to get at them and no computer stuff to deal with either.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    The bolts do loosen over time, hopefully tightening them will stop the leaks. The gaskets get rock hard and brittle over time, so if they still leak, the only thing left to do is replace them.
    Non computer cars are great, but it sure is nice when there is a computer that has a code that tells you exactly what is wrong!
    Jan 2007
    1,673
    Quote Originally Posted by caddydaddy View Post
    Ya---the computer codes do help---but sometimes the codes are a nuisance,like when a problem only happens for a brief second or two and a code pops up and sometimes it stays there until it is cleared manually.
    I do like when the computer kicks the cold idle down on my '95 SD automatically.
    On my '78 SD quadrajet carb----as you know----the cold idle has to knocked down manually by a quick press on acc.pedal after it has warmed up a while.
    Overall i like the PRE--computer Caddy`s better since there`s less pricey things that need repair.
    Andrew78 is offline Cadillac Owners Member
    Automobile(s): 1978 coupe Deville Delegance
    Sep 2010
    Western Australia
    59
    4
    I have just replaced my rocker cover gaskets was a little fiddly but not hard
    remove air filter and be carefull of the egr hose (mine broke with old age )
    make sure gaskets sit correctly as you reinstal the bolts
  13. Remove Advertisements
