4barrel not working! (70 Eldo)
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, 4barrel not working! (70 Eldo) in Cadillac Engine Discussion; ...
    02STSVT's Avatar
    02STSVT is offline Cadillac Owners Member
    Automobile(s): 2002 STS, 1988 Seville R.I.P., 1970 Eldorado (New Toy)
    Oct 2007
    Vermont
    7
    Hey guys, back again with questions about the 70 Eldorado. I have what I believe is the stock Rochester Quadrajet carb on (rebuilt). My problem, (although not preventing me from driving the vehicle) is that the 4barrels are not opening upon WOT. The engine has not been pulled or molested too bad. But I think parts of the vacuum system have been modified. Does anyone have a vacuum diagram for that year? Or any other info to what the problem could be? I don’t think there is a binding issue as I can manually open the top barrels by hand. I also don’t think it’s the rebuilt carb as the other unit I had on the vehicle had the same problem. Thanks again for the help. -Seth
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,869
    Re: 4barrel not working! (70 Eldo)
    The QJ uses an air volume activated set of butterflies (air valve) over the secondary butterflies: You punch WOT and the secondaries slam wide open BUT the air valve (the top "butterfly") prevents a huge bog and stall because they only open in response to airflow and they should have a lockout which prevents opening until the throttle is 3/4 open+. The lockout is either vacuum operated (a diaphragm canister with a pull rod near the passenger side of the secondaries), or a mechanical tang lockout on the accelerator/secondary throttle shaft linkage. (Those top butterflies are NOT operated by engine manifold vacuum: they are operated by engine airflow demand, and you will NEVER see them open while diddling the throttle in neutral...............)
    With the engine off, remove the air cleaner and any interfering baffles or pipes. Try to press open the air valve - it won't open, will it ?? Now, ease the throttle wide open - the air valve will now open. That is the setup to prevent a low speed bog and stall: A QJ will only flow the air required by the engine at any throttle/load opening - a very elegant solution to WOT/low speed power loss. When you do this, watch the secondary metering rod withdrawal - that curved hanger and cam is what pulls the rods to change secondary mixture as the air valve opens with increasing RPM/airflow.
    DO NOT try to remove or bypass the secondary air valve lockout or alter the opening rate: you'll wind up with even far greater problems than you now have......
    Get Doug Roe's HP Books 8 x 11 paperback on Rochester carburetors. Everything you need plus enough to get you in real trouble if you're not a QJ carb guru.
    BRUCE ROE is online now Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    375
    I would add, if the secondaries aren't used for a long time (like some used cars I bought), they can be stuck shut. Also there is a tang from the automatic choke, that keeps them from working until the engine is warmed up. Bruce Roe CLC # 14630
    Captain wow's Avatar
    Captain wow is offline Cadillac Owners Member
    Automobile(s): 1970 Eldorado (prev:78Eldo-73Eldo-79CDV-78Sev-79Sev)
    Nov 2008
    Bristol, UK
    68
    Hey Bruce, By any chance are you any relation to Doug?
    btw im having troubles to and have just bought The manual you mentioned.
    Feb 2006
    55,869
    Quote Originally Posted by Captain wow View Post
    If you run into problems, either PM me or post in here - I build QJ's for marine Olds 455's.
  8. Remove Advertisements
