Throttle rod issue
Results 1 to 8 of 8
500, 472, 425, 368 Discussion, Throttle rod issue in Cadillac Engine Discussion; I've installed the edelbrock intake as well as a new Q-Jet however I the throttle rod seems to be short. ...
    69Deville is offline Cadillac Owners Member
    Automobile(s): 1969 Cadillac Deville
    Mar 2009
    37
    46
    Throttle rod issue
    This lead me to believe that I might have installed it in the wrong place. The other part I'm holding seems to give it enough of an extension to work but unfortunately I didn't take a picture and do not know how to put it back (if I even need to). Any ideas?
    Mar 2009
    37
    46
    Re: Throttle rod issue
    Does anybody has a picture of that area, it would help A LOT? That is the only, and I mean only area I didn't take a picture of.
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    If it were me, I would figure out how much too short it is, and remove the throttle rod and have it lengthened that amount. It could be cut in the center/middle area, and a piece welded in to bring it to the length it needs.
    The rod-end on the throttle rod could then be attached to the arm on the carb without that little bracket shown.
    Feb 2003
    california
    69
    6,680
    You've raised the pivot point of the carb because of the new intake. Looks to me that there's some thread adjustment left at the end. You could also cut the rod in the middle of its length, thread the ends and get a threaded collar from a hardware store to get it precisly correct.
    Mar 2009
    37
    46
    Thats exactly what I did:
    Thanks guys for the input, and with that I was able to drive my car for the first time in 2 years. I really appreciate all the input from you guys here at the forum, this is my first older car so I'm getting use to the technology, with your help, which in my opinion is WAY superior what's out now. However I got to say it feels REAL good to drive her again!
    Mar 2009
    mich
    85
    728
    Good to hear that you have it back on the road
    Swedish DeVille Dude is offline Cadillac Owners Member
    Automobile(s): Cadillac DeVille 1968.
    May 2007
    Stockholm, Sweden.
    69
    Good that you got it up and running again !
    That other thing you wondered about in the first picture is the lever which is connected to the downshift switch (the end with the square hole in it) and then originally rests on the throttle rod plate.
    Regards from Stockholm, Sweden !
    Mar 2009
    37
    46
    Quote Originally Posted by Swedish DeVille Dude View Post
    THATS what it is! Have it now without the kickdown switch and it seems to run fine which is good because its 1 less thing to worry about. Thanks Swedish DeVille Dude!
  11. Remove Advertisements
