Results 1 to 7 of 7
Thread: I need some good brake advise
    dbird35 is offline Cadillac Owners Member
    Automobile(s): 1968
    Jul 2009
    39
    13
    I have a 1968 Deville (472) and I just purchased the front disk brake system from a guy who had a 1969 deville. I took everything from the spindle out plus the poportional valve...My question is do I need to install the poportional and change my brake lines or can I run the same brake lines that was used for the drums? And If I have to change the brake lines is there a place that sells the brake line pre bent......Somebody Plase Help!!!!
    01devilledts's Avatar
    01devilledts is offline Cadillac Owners Fanatic
    Automobile(s): 68 SDV,04 XLR,97&99 4dr tahoe,67 lincoln,98 jeep xj, 69c10
    Dec 2004
    Glendale, Arizona
    35
    392
    Re: I need some good brake advise
    when i did mine on the 68 the only thing i did was have the front flexible lines rebuilt because, I think, the fittings are different where they went into the old drum. Plus my old ones looked worn and I lengthened them for my suspension.
    Also the metal brake line comes out right behind the spindle and on a disc conversion it will need to be moved to the front of the spindle.
    Also there is a brake/suspension area that im sure this would be better in (just my $.02)
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    The proportioning valve is a neccessity. Check that the brake line diameter from the installed system is the same as your drum brakes.
    I don't know the name of the company, someone does make prebent stainless steel lines. I have always bent my own lines. If I do a frame off, I'll use the these stainless lines.
  5. #4
    Dec 2004
    Glendale, Arizona
    35
    392
    I have had no locking/uneven braking problems without the valve.
    I'm sure it is a good idea, but I havent used one on my 65' or the 68' that I'm currently driving now.
    If I "slam" on the brakes, the front will do the same thing as the rear drums.
  6. #5
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Isn't that proportioning valve close to the master cylinder on those old cars? 01devilledts are you sure yours isn't there near the master? That's the way my '70 Impala is; it doesn't even look like a regular prop valve.
  7. #6
    Dec 2004
    Glendale, Arizona
    35
    392
    There is nothing that I can see that that looks out of the ordinary. it goes: Brake Booster, Master Brake Cylinder, Hardlines to the wheels. Unless it is built into the Maser Brake Cylinder (which im sure it wouldn't be with factory 4wheel drums) then I dont think I have one
  8. #7
    Feb 2007
    Maine
    55
    3,310
    kinda sounds like those proportioning valves are over rated and possibly unnecessary.
  • You may not post replies
