425 Rocker Arms
Results 1 to 10 of 10
500, 472, 425, 368 Discussion, 425 Rocker Arms in Cadillac Engine Discussion; Hey all, I removed heads to remove broken ex. manifold bolts. Put everything together and rockers tapping very loud when ...
    cadcamper is offline Cadillac Owners Member
    Dec 2009
    Portland Maine
    58
    9
    425 Rocker Arms
    Hey all, I removed heads to remove broken ex. manifold bolts. Put everything together and rockers tapping very loud when I pulled heads everything was quiet. I used proper torque specs. I'm concerned with the rocker retainers can I use a shaft system on the heads.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,208
    Re: 425 Rocker Arms
    How long did you run the motor after you put it back togther? sometime it has to run for several mins to quiet down and get oil to pump up all the lifters.
    Dec 2009
    Portland Maine
    58
    9
    Re: 425 Rocker Arms
    Ran it half an hour didn't go away. Used proper torque and pre lube. Even soaked lifters in oil before assembly. This engine only has 36,000 miles I'd like to save it. I'm thinking could time have jumped I believe it has nylon gear on cam ?
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: 425 Rocker Arms
    Jumped cam timing would not make the lifters clatter, and it wouldn't run with one tooth off in timing It has to be something else. Check oil pressure with a gauge.
    May 2003
    Massachusetts
    1,208
    Re: 425 Rocker Arms
    You could not have any oil pressure..First thing I would do is find out if I had oil pressure.. take the oil pressure sending unit sensor thats at the back of the block out and screw a gauge in... then pull out the distrubtor out put in a oil pump driver and turn the oil pump with a big elec drill.. see how much pressure you got.... If you can't get any pressure take off the oil pump.. its real eazy.. get a new gasket and make sure its real thin, like .006 thick[guessing]..People have had problems with gaskets made of the wrong material.. you could get a rebuilding kit with new gears.....now clean the pump and pack it with vasoline and put it back on the motor..now drive it with the drill and you should get oil pressure.. and make sure the oil filter is full of oil..
    Dec 2009
    Portland Maine
    58
    9
    Re: 425 Rocker Arms
    I have oil pressure. I ran it with valve covers off and have noticed the rockers are loose and twist side to side. This motor has retainers on it where tabs hold rockers in place this is first motor I've seen with these I've been all over the net and can't find info or replacements. I'm used to shaft rockers. I have manuals to this car but no info on adjusting this type of rocker. Car goes fine but inspection stations here in Maine believe the noise to be exhaust leak so they won.t pass it. Its not exhaust I tell them I know the difference.
    May 2003
    Massachusetts
    1,208
    Re: 425 Rocker Arms
    Did you put any other new parts in ? When you took the lifters out did you put them back in the same hole? If you got new lifters, they could be the wrong ones.. chevy lifters are just a little bit shorter and would cause noise if used..
    Dec 2009
    Portland Maine
    58
    9
    Re: 425 Rocker Arms
    Same lifters same holes as well as the rods. I marked everything as it came out. Been down that road before. I've got a chance to get a 500 for $650 thinking I'd be further ahead seems parts are more readily available and all the outside stuff on 425 should fit. I still would like to figure out problem just for gp.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: 425 Rocker Arms
    One of my 425's develops a lifter tick, which I attribute to bleed down. Drives me crazy. Take the car out on the Interstate and blast it up to 80 mph. and the tick goes away for 5 - 6 days.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: 425 Rocker Arms
    Those are called non-adjustable rocker arms. There isn't much you can do with them other than replace them. They can get a little ticky but I can't imagine it would be loud enough to be mistaken for an exhaust leak. With only 36.000 miles they should be in good shape anyway. I would have almost guessed a burnt valve; you didn't see any when the heads were off huh? Our local Midas shop uses a lot of orange silicone on their exhaust jobs; stubborn leaks may require deperate measures like that. If an inspection station says it has an exhaust leak they should be able to point it out to you while it is on the lift.
  13. Remove Advertisements
