Points type distributor or HEI
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, Points type distributor or HEI in Cadillac Engine Discussion; I'm not quite sure if this is a High Energy Ignition HEI or a points type distributor on my 1971 ...
    arce1971 is offline Cadillac Owners Member
    Automobile(s): 1971 Coupe Deville, 1973 Fleetwood Sixty-Special, 98 Deville
    Oct 2009
    31
    13
    I'm not quite sure if this is a High Energy Ignition HEI or a points type distributor on my 1971 Coupe Deville 472. The MSD part number is Ignition Coil PN# 8203.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Points type distributor or HEI
    Points, HEI has the coil in the cap.
    Oct 2009
    31
    13
    Thank you..I am going to change it to HEI
    Feb 2007
    Maine
    55
    3,310
    You won't regret it
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    When you put in the HEI make sure you use a new wire to power it. The points distrubtor wire has a resistor in it...
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Some of the posts here a while back mention the issue of the double belts being in the way, and using a single belt. You may find that info with a search. The HEI is larger of course.
    You can find a switched 12 volt spade on the fuse block that will work for the HEI power. Use at least a #16, or even a #14 power wire to the dist.
  9. Remove Advertisements
