1970 500 not running right!
Results 1 to 9 of 9
500, 472, 425, 368 Discussion, 1970 500 not running right! in Cadillac Engine Discussion; ...
    02STSVT's Avatar
    02STSVT is offline Cadillac Owners Member
    Automobile(s): 2002 STS, 1988 Seville R.I.P., 1970 Eldorado (New Toy)
    Oct 2007
    Vermont
    7
    Ok guys hereís how it goes. A couple of weekends ago I took my 1970 Eldorado with 57K miles out for a drive around town. She ran great! I just took a weekend ride; I didnít beat on her, didnít fool around or anything, just went for a ride. I came home, parked the car in the driveway and went inside. About 3 hours later I decided it was time to put her away in the garage. I started the engine and it stalled right away. So I tried again, managed to get it running, but it would not idle. I figured I did something and hoped the issue would resolve itself. The next day the car ran like crap. No power to speak of, difficult to start and I had to drive like an old lady with on foot on the gas to keep it from stalling. I decided to replace the distributor cap, rotor, checked plugs and wires and finally broke down and had a spare carb rebuilt and put on the car. The rebuilt carburetor seemed to help a little bit, but did not solve the problem. So I donít think its fuel related. Next I took the car to a local shop where they determined that the timing was way off, it is very late. Currently they are trying to get the distributor to turn so they can set the timing but are having trouble getting it to move. But no guarantee thatís gonna fix the problem. Any ideas guys? I really donít think itís the timing chain since this problem just happened all at once. Iím thinking that there is something going on inside the distributor. Any help Iíd really appreciate! Thanks, Seth
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,210
    Re: 1970 500 not running right!
    What I think happened is the plastic coating on the timing gear broke and came off... happenes alot when the motor is shut off...Check to see if there is too much play in the chain and gears...jumping a tooth will bend valves... Do not use a cheap $35 chain and gears... the good ones are $85 to $100 plus and are sprokets and roller chain...
    02STSVT's Avatar
    Oct 2007
    Vermont
    7
    Thanks for the quick reply! So this plastic coating on the timing gear is behind the timing cover right? Or is that something in the distributor. It did seem as if the rotor had a little too much play in it. I really do want to avoid getting into that timing cover. Thanks again!
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Yes, it's behind the timing cover. If it failed, it's likely because of age. Plastic does get brittle with age sometimes. It's not likely your distributor. If the timing is late now, as opposed to where it was earlier, the timing sprocket is highly suspect, and the chain may have moved a whole tooth on the sprocket. That's also what bends valves, when the cam is retarded, like drmenard said. The auto shop you went to should have known that when the timing became late, the timing set was affected by the sprocket failure.
    BRUCE ROE is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado
    Jun 2009
    399
    You can check the timing chain. Rock the crank by hand, see how many degrees it goes before the distributor rotor starts to follow it. 6 degrees means its gone. Even if it hasn't failed outright yet, it probably will. Change it now, or the car will tell you when to change it (at the side of the road). Bruce Roe CLC # 14630
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    If the distributor is frozen to the block, I doubt if the timing moved. I would check the vacuum. It's usually always a problem with points and condenser. Back in the day I couldn't get a set of points to last over a year.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    How have you made out with this problem?
    02STSVT's Avatar
    Oct 2007
    Vermont
    7
    Hey guys. Well its all fixed. Seemed it did jump timing after all! Thankfully it does not appear any damage was done. Now on with the small stuff
    Mar 2009
    mich
    85
    728
    Great to hear you have it fixed OK
  12. Remove Advertisements
