| 500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines. | Cadillac Forums: Removing the A/C compressor on a 472
10-30-09, 02:13 PM
| | Cadillac Owners Member Cadillac(s): 1971 Coupe Deville, 1973 Fleetwood Sixty-Special, 98 Deville | | Join Date: Oct 2009 Age: 24 | | | Removing the A/C compressor on a 472  Hello first time posting..How do I remove the A/C compressor off my 472 1973 Fleetwood? Do I have to change anything? Im never going to use it, so I want to get rid of some clutter.. |
10-30-09, 05:33 PM
|  | Cadillac Owners Fanatic Cadillac(s): '81 CDV, '81 FWB, '95 SDV | | Join Date: May 2009 Location: Limerick, PA Age: 31 | | | Re: Removing the A/C compressor on a 472 When we pulled mine, we just unbolted the mounts and pulled the thing out. I think there's only 4 bolts holding it in? It's been about 8 years since I did it. We unscrewed all the lines and everything associated with it. I just left all the lines open that weren't being used. I love not having the compressor, it's so much easier to work on now, and the thing weighs a ton. You'll have to get a shorter belt to bypass it. There should be an option for a non a/c car at the local parts store, so they'll have the part number. I forget the name for the smaller radiator in front of the radiator (been awake too long) but you can get rid of that too. More air for the cooling system. Now you can use a taller aluminum intake manifold. |
10-31-09, 12:02 AM
| | Cadillac Owners Fanatic Cadillac(s): '85 FWD fleetwood, '93 fleetwood Bro | | Join Date: Mar 2009 Location: mich Age: 78 | | | Re: Removing the A/C compressor on a 472 Angry Matt was thinking of the condenser, which is in front of the radiator. You can toss that too if you are gonna do away with AC.  |
11-03-09, 09:23 AM
|  | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Oct 2006 Location: Dublin, Ireland | | | Re: Removing the A/C compressor on a 472 Hey, good luck
I have been wanting to get rid of mine for a while - bolts SEIZED !
Sick of it, want it to go away now please
Please post up your progress on those stinkin' bolts
jon |
11-04-09, 09:08 AM
| | Cadillac Owners Member Cadillac(s): 1971 Coupe Deville, 1973 Fleetwood Sixty-Special, 98 Deville | | Join Date: Oct 2009 Age: 24 | | | Re: Removing the A/C compressor on a 472 Hey thanks alot guys..I'm going to get to it this weekend. Hopefully I dont have that problem with the bolts. |
11-07-09, 02:15 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 94 Deville, 2000 STS, 2005 Escalade 2WD | | Join Date: Jan 2003 Location: Portland, ME Age: 28 | | | Re: Removing the A/C compressor on a 472 Also, be sure to put the rear compressor bolts back into the manifold. I'm pretty sure the bolt holes go into the ports, so if you leave the bolt out, you'll have a massive vacuum leak! Trust me, I know from removing the compressor on a 425!  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
