Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: Starter problems on 1977 425
Old 10-26-09, 06:42 PM
Cadillac(s): Cadillac
View prs1989's Photo Album
Casino Cash: $2866
Hey guys, me and a friend just picked up a 1977 Cadillac Hearse, and we are hoping to get it running for Halloween. It is very rough cosmetically...but it supposedly runs and drives well. It hasn't been started in about a month. So all the fluids are full and we put in a brand new battery. I cranked it for about 6 or 7 seconds, then stopped, so we could prime it again and so I didn't overheat the starter. I went to crank it again, and it just made a CLUNK sound. Checked the battery and it was at 12.58, a 700 CCA battery that is brand new. Got a different battery and the same thing. So I am thinking the starter went out? I can hear the clunk but that's it. I tried tapping it with a hammer, and one time it sounded like it made "half a crank" but then went right back to clunking. So... is a starter all that difficult to do on the 425? I honestly never did a starter before, but I think I can do it, it looks like maybe 2 bolts and some wiring. Is this something I can do myself? I have done plenty of other things on cars...just never a starter. The only other thing I was wondering is when I put the new starter in do I have to like align it in a certain way so the teeth line up or will it just kinda snap in place?
I was planning to do it tomorrow in the driveway, so if there is any suggestions or things to look out for please let me know, or any other diagnosis, although I'm 99.9% sure the starter went.
Thanks
  #2 (permalink)
Old 10-26-09, 07:36 PM
Cadillac(s): 95 fleetwood 81 deville
View drmenard's Photo Album
Casino Cash: $4307
Re: Starter problems on 1977 425
disconnet a battery terminal first.. pull out the starter and bring it to Autozone and ask them to check it .. I think they still do that.. or there might be a local rebuilder who can check it out... starters are as cheap as $40 there... go with the cheap one if it tests bad...
  #3 (permalink)
Old 10-26-09, 11:25 PM
Angry Matt's Avatar
Cadillac(s): '81 CDV, '81 FWB, '95 SDV
View Angry Matt's Photo Album
Casino Cash: $4695
Starters are very easy to do on these cars. They're heavier then they look though, so just don't let it fall on your head when you unbolt it. Two bolts hold it in and one nut on the power wire stud (don't overtighten it or it will strip, but make sure it's tight). That is a hot wire with no fuse so disconnect the ground from the battery before doing anything. If there are any shims, save them and put them back the way they came out. Definitely a driveway job, half hour if all goes smooth.
Yes, it will just line up. The teeth turn freely on the starter. Check the old starter and the flywheel for improper wear on the teeth, like clipped corners or missing teeth.
I like to hook mine to jumper cables to see if it turns freely when it's out of the car, although it's not under load so it's probably not an effective test, just for fun.
  #4 (permalink)
Old 10-27-09, 10:16 PM
Cadillac(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
View deVille33's Photo Album
Casino Cash: $4375
There should be another support brace at the front of the starter. These High Torque starters are prone to flex and that front brace is neccessary. You should check your ground cable with a digital multigauge to ensure that the cable is good. I chased this problem for a week before I determined that the ground cable was bad.
  #5 (permalink)
Old 10-30-09, 09:18 AM
Cadillac(s): 94 ETC 78 Eldo 69 Eldo
View hardley-etc's Photo Album
Casino Cash: $325
if you put in a known good battery
turn on the head lights and try to start
if they go dim when key is turned
check the engine ground strap
clean the connections up good
make sure all are tight
if won't start now
might be starter
make sure hot wire going to starter is not oil soaked either
Tags: , ,
1977, 425, problems, starter
