Which Edelbrock carburators to install
Results 1 to 5 of 5
500, 472, 425, 368 Discussion, Which Edelbrock carburators to install in Cadillac Engine Discussion; I have a 68 cadillac deville with a 472 and I was wondering if I decided to change the carburator, ...
    dbird35 is offline Cadillac Owners Member
    Automobile(s): 1968
    Jul 2009
    39
    13
    I have a 68 cadillac deville with a 472 and I was wondering if I decided to change the carburator, which Edelbrock carburator should I put in it? I know this maybe a simple answer but I really don't know.....thanks in advance
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Re: Which Edelbrock carburators to install
    I'm Not familiar with your year. What is the original carb?? I'm on several other forums, and folks have been having problems with the Edlebrock carbs, but I don't know which models. The original carb on some 60s cars was a Carter AFB, which is a very good, simple carb. Edlebrock makes a copy of that carb. They also make a Quadra-jet style carb. I haven't ever used their carbs.
    The question is, why do you want to change the carb??
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    No other carb will outperform your original Rochester Quadrajet. I would have the original rebuilt.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    I agree with Al. Your Rochester Quad can flow at 800 cfms and has several advantages over other carbs. The biggest problem is throttle shaft wear. A good carb shop should be able to correct this, if tbat is a problem.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    Yep - an OEM 750-800 QJ will supply over 700 cubic inches. That's why they have secondary air valves - so you won't "over carburete" the engine.
    We use electric choke QJ's on our marine work and race Olds 455's, most done by JET in California, and not expensive.
    Get to www.jetchip.com and look at their site and give them a phone call. They're very helpful and will build a QJ for any application.
    I'm not knocking Vic Edelbrock's work - we use a ton of his parts - but JET will build a carb for your engine.
  8. Remove Advertisements
