Results 1 to 4 of 4
Thread: Compression Test on 472
    BobCatwood's Avatar
    BobCatwood is offline Cadillac Owners Member
    Automobile(s): 1969 Coupe de Ville
    Aug 2009
    San Joaquin Valley, CA
    37
    So my wife inherited a '69 Coupe DeVille with a freshly rebuilt 472. She drove it for about 20,000 miles and then parked it about 7 years ago prior to us getting together. Due to time and money restraints, I haven't had a chance to really take a look at it until recently. Last week I decided to try and get it up and running and was able to do so with very little trouble. The engine has some performance upgrades (Edelbrock carb and intake, Mallory ignition, and from the sounds of things a cam) and I'd like to try to determine a few more things so I know what I'm working with. I'd also like to see if sitting for 7 years had any negative effects on the engine. So my questions are: How many psi should a stock 472 put out during a compression test and how can I determine compression ratio from the test?
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: Compression Test on 472
    When you do a compression test, your not neccessarily looking for the numbers, but the range of difference of the readings. A high compression engine will generally have about 150# readings.
    Take and record your readings. If your readings are more than 15#s out of the mean average range of the readings, you should do more diagnostics to determine the reason.
    BobCatwood's Avatar
    Aug 2009
    37
    Well the compression looks good. Drivers side front to back was 146, 146, 148, 150. Passenger side front to back was 146, 143, 145, 144.
  5. #4
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Those numbers look OK for an engine that has sat idle for some years. After it gets driven for a while, the numbers may come up a bit. Adding some Marvel Mystery oil to the engine oil should help clean things up in there, like the lifters, rings, etc.
  • You may not post replies
