Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: new timing set
Old 07-14-09, 08:15 PM
Cadillac(s): none
View cowboycadillac556's Photo Album
Casino Cash: $505
new timing set
I am kinda learning as i go here and am trying to get my new timing chain in and am wondering what cylinder should be in "firing position"? please excuse my mechanical grammar or lack there of. I have read that #4 should be in firing position, does this make the marks line up? and also how should the distributor be set?
  #2 (permalink)
Old 07-14-09, 08:59 PM
Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville
View cadillac_al's Photo Album
Casino Cash: $10185
Re: new timing set
Whew, it's been a while, but I'm positive #1 has to be at top dead center with both valves closed
  #3 (permalink)
Old 07-14-09, 09:34 PM
Cadillac(s): none
Casino Cash: $505
Re: new timing set
it might be helpful to know that the engine is a 74 472, also my heads are at the machine shop till friday and i am trying to get this done together before they come back.
  #4 (permalink)
Old 07-15-09, 01:39 AM
Cadillac(s): '85 FWD fleetwood, '93 fleetwood Bro
View steelybill's Photo Album
Casino Cash: $2320
Re: new timing set
On the 472/500 engines, when the timing marks on the chain sprockets are lined up, #1 is NOT at top-dead-center. It's on the exhaust stroke. You have to rotate the crankshaft 1 full turn (to the timing mark) to get the distributor timed to the #1 firing position.
Kinda strange why it's that way, but even the firing order and cylinder numbers are different than most engines, with number one cylinder being on the right-front. Firing order FYI is 1-5-6-3-4-2-7-8
  #5 (permalink)
Old 07-15-09, 02:11 AM
Cadillac(s): none
Casino Cash: $505
Re: new timing set
will it run if I just line the marks up?
  #6 (permalink)
Old 07-15-09, 02:17 AM
Cadillac(s): Eldorado
View BRUCE ROE's Photo Album
Casino Cash: $3660
Re: new timing set
Right, Cad lines up on cylinder 4. I wrestle the old timing marks to line up, then take the cap off the distributor & mark the exact position of the rotor to the distributor. The distributor to engine can be marked also to get you on the same tooth. But expect that to move a little due to the new chain (if the rotor is exact). Bruce Roe CLC #14630
set, timing
