Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > 500, 472, 425, 368
500, 472, 425, 368 This forum is to discuss the old big block Cadillac engines.
Cadillac Forums: 1980 cadillac 368 HEI question
Old 06-24-09, 04:10 PM
Cadillac(s): 4
View team26's Photo Album
Casino Cash: $300
ok - I have a 1980 fleetwood with the 368 in it. Pulled the body off the frame ( derby car - not a driver ). trying to get spark out of the iginition - no luck.
I have 12 volts going to the HEI ( like the one wire setup ) - my concern is the 4 wire plug comin out of the LOWER side of the distributor - Do I need to do anything with these? twist them together ? give power to some? unsure on what to do here?
I have replaced the cap/coil/rotor and ignition module (5 wire )
Any help...please....
  #2 (permalink)
Old 06-25-09, 08:32 AM
Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville
View cadillac_al's Photo Album
Casino Cash: $10185
Re: 1980 cadillac 368 HEI question
I can't remember when they started adding more wires to the HEI but I think you need to look for an older HEI Distributer.
  #3 (permalink)
Old 06-25-09, 09:05 AM
Cadillac(s): 4
Casino Cash: $300
That is kinda what I thought - I just didn't know if there was a workaround.
I also have a 79 Fleetwood that I built this year with th 425 in it. That has a 4 prong ignition module ( 2 on each side ) There are no other wires coming out except for the one wire hookup to the battery. In 1980 - they started with the 5 prong ignition module ( 2 on side - 3 on other ) that is when they started having "other " wires coming out of the distributor.
Thanks for helping me confirm it Al.
  #4 (permalink)
Old 06-25-09, 12:46 PM
CadVetteStang's Avatar
Cadillac(s): 70 Eldorado w/500, 82 Eldorado w/472, 72 Mustang w/Cad 500
View CadVetteStang's Photo Album
Casino Cash: $1070
The 4 wires are what the computer hooks to set the timing advance. If you are not using the computer to control the car’s engine management system, then you need an HEI with vacuum advance. 74-79 years - 425, 472 and 500 engines will all work. Keep that distributor and sell it or give it away- they are becoming more rare and are needed when someone wants to run fuel injection on a 435, 472, or 500.
1980, 368, cadillac, hei, question
