Headlight door help on 68 Eldorado
Results 1 to 2 of 2
500, 472, 425, 368 Discussion, Headlight door help on 68 Eldorado in Cadillac Engine Discussion; I have a 68 Eldo that the headlight doors do not work. I know I'm probably the only one with ...
    Kim H is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    6
    I have a 68 Eldo that the headlight doors do not work. I know I'm probably the only one with this problem. I can get mine to open and close by playing with the vacume lines under the hood but I can not get the switch to open them. I would think the pneumatic part of the switch would be failsafe. It looks like the hoses are hooked up correctly to the switch and I do not hear any air leaks under the dash. Is there a common problem to check for?
    Other than buying an impossible to find, expensive, new switch is there any other options out there? How about a remote underhood pneumatic switch from another vehicle?
    Hoping someone has some experience with this.
    andy-gts is offline Cadillac Owners Member
    Automobile(s): 68 and 70 eldorado
    Sep 2009
    53
    9
    Re: Headlight door help on 68 Eldorado
    Hi ,
    Did you ever get the switch to work or finda replacement? JUst curious, I have a 68 and everything except the cruise works.
    good luck
