68 Deville Front window fogging
Results 1 to 6 of 6
500, 472, 425, 368 Discussion, 68 Deville Front window fogging in Cadillac Engine Discussion; Ive noticed that lately wen I park my car the window will fog up with all the windows down to. ...
    68deville&99escalade is offline Cadillac Owners Member
    Jul 2004
    17
    Ive noticed that lately wen I park my car the window will fog up with all the windows down to. And you can also see if your sitting in it or driving, you can see steam coming out of the dash & fogging it up. When I turn on the defrost it gets 10X worse and then takes forever to go down. Even to wipe it takes a long time with a piece of kleenex. U got to wipe over the same spot like 6X.
    Anyone know what this is?
    lux hauler is offline Cadillac Owners Connoisseur
    Jan 2003
    Ohio
    47
    1,258
    Re: 68 Deville Front window fogging
    leaking heater core would be my guess.
    tripleyellow78cad's Avatar
    tripleyellow78cad is offline Cadillac Owners Fanatic
    Mar 2004
    central california
    37
    127
    Quote Originally Posted by 68deville&99escalade
    Your heater core must have started leaking , i had the same problem in my 78 coupe
    Jul 2004
    17
    What should I do then? Just bypass it? I only drive the car in the summer. So heat isnt important to me. Will this fix the problem.
    TheCanadianWannabe is offline Cadillac Owners Member
    Mar 2004
    Winnipeg, Manitoba, Canada
    36
    17
    I was experiencing fogging too and had to bypass the heater core on my '68 Deville because it was leaking like crazy from 2 different spots. I know I'll need to fix it sometime and I was thinking about patching the leaks with some kind of epoxy compound. Any suggestions or should I start looking for a new heater core? Are they fixable/rebuildable?
    Jan 2003
    Ohio
    47
    1,258
    there should be no problem by-passing it.
    i'm not sure how hard the core is to get to in your car but the ones that i've done were a PITA. i wouldn't worry about trying to fix one....just get a new one. to me, it wouldn't be worth the trouble.
  9. Remove Advertisements
